  • SN95 4.6L Mustang Tech
Rear Bearing Nut Size
  • Thread starter Thread starter NYStang2002
  • Start date Start date Sep 22, 2012
NYStang2002
231
Wappingers Falls, New York
Sep 22, 2012
  • Sep 22, 2012
I'm going to replace a rear bearing tomorrow and would like to know what size is the rear bearing nut. What size socket do I need? TIA
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Sep 22, 2012
  • Sep 22, 2012
Which nut are you talking about? On these year mustangs you take apart the rear brakes down to taking the rotors off. Then you take off the diff cover, the bolt holding the pin in the diff center section. Then you take the pin out, pull the c-clips and pull the axles out. At that point you remove the rear axle seals and use a slide hammer to take the rear bearings out. You have to hammer the new bearings in and then you can reverse the procedure making sure you dont get grease on the brake pads or rotors. Make sure to refill the diff when you are done.
As far as fastener sizes, its been a bit since I have done one. You will want a fairly complete set of metric and standard size sockets with associated ratchets and wrenches to your brand preference.
NYStang2002
231
Sep 22, 2012
  • Sep 22, 2012
My bad I should have been more specific. I'm replacing the rear wheel bearing.
Sent from my Nexus 7 using Tapatalk 2
trinity_gt
3,125
81
99
Canada
Sep 22, 2012
  • Sep 22, 2012
bdcardinal's description of the process still applies: remove the axle as described, pop the seal out and use a slide-hammer to yank the bearing out.
There is no one "nut" to this process. It's not like the front wheel hub assembly that really is retained by a giant 36mm nut torqued to 260 ft-lbs. More work is required to get to the rear axle bearing...
Edit: You are talking about a solid-axle assembly and not an IRS, right?
94GTCoupe
1,412
92
79
CA
Sep 23, 2012
  • Sep 23, 2012
This should help.
For solid rear end.
Show up to removing the wheel bearings with a slide hammer, as mine didn't need replacing.
http://www.stangnet.com/mustang-for...ll-cobra-rear-brake-kit-m-2300-m-pics.828925/
identifying smog/fuel part on 1998 GT
  • dochawk
  • Jun 18, 2026
SN95 4.6L Mustang Tech Jun 30, 2026
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
ABS flare nuts (*the 2 on the side*)
  • saf_blu302
  • Feb 17, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 17, 2026
AeroCoupe
R
Fox Foxbody Notchback Coupe 1979
  • robrouck
  • Apr 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 20, 2026
slow84lx
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
