Rear Brake/turn Signal Light Dead
Can you be more specific? Both rear brake lights? both turn signals?
What do you mean "ordinary taillight works" Do you mean that when you turn the headlight switch on then the rear lights light up?
First check your fuses then we will go from there.
Hi, it is only the passenger side that were the turn signal and brake light does not work. Headlights are fine on both sides.
