rear defroster
  • Thread starter Thread starter dustman69
  • Start date Start date Nov 23, 2006
D
dustman69
  • Nov 23, 2006
what could make my rear defroster quit working? wires to rear glass hooked up and checked the fuses. could it be the switch and if so is it a dealer item.
HISSIN50
34
129
Nov 23, 2006
  • Nov 23, 2006
You can check for power in and out of the switch. If good, then go to the back window and check for power making it to the first defroster line.
Good luck.
Black1987Stang
1,422
Jersey Shore
Nov 23, 2006
  • Nov 23, 2006
This reminds me I got to get mine working good for the snow this winter, when I turn it on only 2 of the lines heat up, guess I gotta whip out the voltmeter later and figure out where its cutting out, Ive seen some conductive tape thats supposed to be made for fixing those circuits, anybody have experience with them or anything?
HISSIN50
34
129
Nov 23, 2006
  • Nov 23, 2006
Way back when you could get conductive paint (it was kinda like touch-up paint). I seem to recall it working well.
83 Capri 5.0
92
Vancouver, Canada
Nov 23, 2006
  • Nov 23, 2006
Yup, just bought some conductive paint, I have the same thing, 3 lines of defrost working.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Nov 23, 2006
  • Nov 23, 2006
As much as I hate the Company, JC Whitney carries that paint and glue for sticking the main wires back on and it does work well.
Black1987Stang
1,422
Jersey Shore
Nov 24, 2006
  • Nov 24, 2006
alright well I just was checking all those lines for power, I found a bunch of open spots, most are even on the same line, if I kneeled down and looked through the grids in the light I could see where all the opens are so that makes it alot easier to find. From what I figured out with myvoltmeter the driver side wire is the power source wire where the 12v comes from, and the passenger side wire is the grounding side? correct....and obviously the defroster wires is the resistance in the circuit......I remember seeing Advance or Autozone had some kinda metallic tape or liquid for defrosters, ill check them out tomorrow
HISSIN50
34
129
Nov 24, 2006
  • Nov 24, 2006
That sounds about right to me. There might be a resistor in the wiring too.
Tangent: On one car that had a broken line and tint, I took a CPU fan and installed it in the top passenger corner of the back window. It was powered with the 12 volts to the defroster and when I turned the defroster on, the fan come on and cleared about 3/4 of the back window.
It wasnt pretty but worked for the application (I live in the desert - that would not have flown in Seattle though).
Good luck.
Electrical Defrost switch ignition?
  • Teen'93stang5.0
  • May 16, 2026
Fox 5.0 Mustang Tech Jun 3, 2026
Teen'93stang5.0
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Fox 5.0 Mustang Tech 16 minutes ago
AeroCoupe
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
D
Theft light staying on car starts right up
  • dtarang
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 15, 2026
dtarang
D
