Rear-End gears
  • Thread starter Thread starter hemi_fan
  • Start date Start date Jun 3, 2004
hemi_fan
279
Ontario, Canada
Jun 3, 2004
  • Jun 3, 2004
I want to get some 4.10 gears for my car. I opted for them since I dont really do any highway driving, so they shouldnt hurt my mileage much, and they should give me a performance boost. BUT, what parts do I need to get in order to do a complete change to 4.10 gears other than the basic Ring and Pinion gears...?
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jun 3, 2004
  • Jun 3, 2004
http://secure.50resto.com/product1.cfm?SID=1&Product_ID=1904&Category_ID=652
get that and some new gear oil and friction modifier. you might want to go ahead and rebuild the tracloc also and replace your axle bearings since the axles will come out anyways
hemi_fan
279
Ontario, Canada
Jun 3, 2004
  • Jun 3, 2004
thanks, i was lookin at that, just wasnt sure if thats what i needed.
hemi_fan
279
Ontario, Canada
Jun 3, 2004
  • Jun 3, 2004
Any idea how much gears would shave off of a 1/4 time? Say for example that I run 15.0 seconds stock with my 3.08s... any estimates?
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jun 3, 2004
  • Jun 3, 2004
You'll probally be in the low 14's, maby even 13's with something sticky on the rear wheels. Your going to love them!!!
beaver2489
503
st. joseph missouri
Jun 3, 2004
  • Jun 3, 2004
going from 2.73's to 4.10's in a 5speed is supposed to shave off about .4sec +/-. It makes a huge SOTP difference. Oh, and I used some red RTV silicone to seal the rear cover. and go to walmart, they have a gear oil pump that screws to the top of the bottle and pumps the gear lube through a hose into the pumpkin. makes less of a mess. don't forget to put the friction mod fluid in!
maverick0716
3,924
Chilliwack, BC, Canada
Jun 3, 2004
  • Jun 3, 2004
Yeah, maybe if you're roasting off the tires with the 4.10s.......in reality if you can get it to hook, you'll see huge gains.
hemi_fan
279
Ontario, Canada
Jun 3, 2004
  • Jun 3, 2004
Wow, really!?! a full second off my times on a tire!?! thats wicked man. i thought it would be like .3 seconds or something...
fordman54935
301
Wisconsin
Jun 4, 2004
  • Jun 4, 2004
If you plan on doing the swap yourself, you'll need a dial indicator and magnetic base to set the backlash. Also, inspect the carrier bearings and races as well as the wheel bearings, and I'd replace the axle seals too while you have the axles out (even if they aren't leaking). Other than that, you'll need some new shims as well to get the backlash set properly, which are available at your local Ford dealership or tranny/rear-end shop. There is a chart in the Chilton's Mustang repair manual that tells you which shim to use to correct for X amount of backlash, or i'm sure the dealership could has that chart available also.
Hope this helps!
K
Drivetrain '87 5.0 Installing New Ring Gear and Pinion - Pattern Questions
  • karhoot
  • Apr 23, 2026
Fox 5.0 Mustang Tech May 9, 2026
Mindseye007
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
