rear end
  • Thread starter Thread starter jacob_9249
  • Start date Start date Jun 15, 2008
J
jacob_9249
tn
Jun 15, 2008
  • Jun 15, 2008
does anyone know about how much horse and torque a 7.5 rear end will hold.
lx93notch
24
coventry, rhode island
Jun 16, 2008
  • Jun 16, 2008
the 7.5 would be ok if your doin a 5.0 swap and dont want posi. if your goin any bigger than a 5.0 i would get a 8.8 rear. the swap itself isnt that hard. you just have to fight old rusty stuff, but is nothing a s*** load of penetrating oil cant fix. i just did the swap in my 93 coupe bout 5 months ago and i think the hardest part was gettin the dam brake lines replaced and flared
bynummustang
Seen my other Jackstand?
Jul 24, 2005
NC State University
Jun 17, 2008
  • Jun 17, 2008
In my mind, 8.8 is best for under 350 torque. Anything over that, I'd say 9 inch, but I'm one cautious SOB.
lx93notch
24
Jun 17, 2008
  • Jun 17, 2008
yea i would go with that if you have the money to do that swap. we have had a couple of shelbys come in here at work with rear end noise complaints and the housing itself was actually stretched wider from the power
C
convo351pro
15
  • Jun 17, 2008
It depends on how the torque is getting to the axles.. if you run a 5 speed and lauch pretty high it won't last long. However if you run an automatic there is no real big bang of power hitting the axles, I've seen a 82 mustang run 11.6 in the 1/4 mile, C4 automatic, and 7.5" rear.
I hope this helps!
slow84lx
clean it good before insertion
Jul 3, 2005
372
180
63
Dallas, TX
Jun 18, 2008
  • Jun 18, 2008
A stock 5.0, or even 3.8 in a few cases can break the 7.5. When not abused the 7.5 can last a very long time. The AOD cars are much easier on the rearend than the stick cars are.
BTW, early Fox v8 mustangs with the 7.5 will also have traction lok.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Jun 18, 2008
  • Jun 18, 2008
7.5 will hold up a little while. They are not posi, but when I did my 5.0 T5 swap into my 4cyl coupe, I rolled on the 7.5 axle til my 8.8 was built. I one wheel peeled it around town for a few weeks, and no breakage. My 5.0L engine was stock, with exhaust.
You can make the 7.5 a posi, and weld the tubes if you don't have access to an 8.8. The swap is easy as said, I would also buy some LCA's while it's out. That will help wheel hop, and traction.
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
R
Interior and Upholstery How to remove seatbelt torx screw
  • Riley Barth
  • Jul 6, 2026
Fox 5.0 Mustang Tech Jul 13, 2026
D
What's it Worth? Considering Selling '82 Fairmont Futura Body Shell
  • DonMay63
  • Apr 5, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Apr 5, 2026
DonMay63
D
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
J
Rear alignment issues
  • Jayjay001
  • May 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
