  • 1994 - 1995 Specific Tech
rear gear oil
  • Thread starter Thread starter BlueSaph95GT
  • Start date Start date Oct 21, 2004
BlueSaph95GT
123
Oak Lawn IL
Oct 21, 2004
  • Oct 21, 2004
how many quarts should i buy for a rear gear swap? i'm thinking of buying the Redline Synthetic 75W90...i just need to know how much (or a different weight oil if i'm picking the wrong one...)
F
fiveo'cobra
241
SC
Oct 21, 2004
  • Oct 21, 2004
you're gonna need about two quarts to be on the safe side and you need to stay away from the syn oil when it comes to gears. Get regular gear oil because its nice and thick. The syn oil=great for engines, not that great for gears. The best i can think of is either "Redline" or "Royal Purple" oils. They are both top notch.
BlueSaph95GT
123
Oak Lawn IL
Oct 21, 2004
  • Oct 21, 2004
call me crazy, but i thought both royal purple and redline were synthetic gear oils? i didn't think they made any non-synthetics...
TrueBlue95GT
966
Connecticut
Oct 21, 2004
  • Oct 21, 2004
I use Mobil 1 Synthetic. From what it says in the Haynes Manual, we're supposed to use synthetic ATF for our differential.
RIO5.0
6,892
N.H.
Oct 21, 2004
  • Oct 21, 2004
You run ATF in the tranny, not the rear..
Its takes good ole 80w or so for the dif...
I swapped over to synthetic back 10k ago when i rebuilt my Trak-Loc...the oil was damn clean and still see thru, so I just filtered it and threw it right back in when it put 373s in last week...
Venom351R
4,548
41
98
MAINE
Oct 21, 2004
  • Oct 21, 2004
Regular NAPA gear oil is just fine, thats what I run in mine.
FYI If you have an aftermarket differential like an EATON or AUBURN then YOU DONT want to run synthetic oil in it. Belive it or not but its not good for them. My friend chris just took out his auburn and put a rebuilt stocker back in b/c the auburn was only spinning one tire b/c it was trashed from using syntehic oil. Just a heads up........
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
