  • SN95 4.6L Mustang Tech
rear jacking points?
  • Thread starter Thread starter DerekStangGT
  • Start date Start date Jan 18, 2004
D
DerekStangGT
My package is in the mail!
Feb 18, 2003
1,068
Jan 18, 2004
  • Jan 18, 2004
i know i can place the jackstands under the rear axles, just outside the differential, but where can i jack the car up? i plan on driving the front onto those rhino ramps
01'TRUE BLUE GT
4,984
Pittsburgh, PA.
Jan 18, 2004
  • Jan 18, 2004
I've been lifting mine from the differential since day one and no problems. You have to be careful you don't catch the cover though.
D
DerekStangGT
Feb 18, 2003
1,068
Jan 19, 2004
  • Jan 19, 2004
i remember reading somwhere that is a big they said it cant support all the weight
01'TRUE BLUE GT
4,984
Pittsburgh, PA.
Jan 19, 2004
  • Jan 19, 2004
I don't care what "they" say, that's the only way I've ever lifted mine in the rear and I never had any trouble. I've done that for years with all my RWD cars and never had any issues. It can't support all the weight???? What do you think drives all that weight when it's on the ground? If you don't feel comfortable doing it my way, then don't do it.
MT1083
1,033
Charlotte, NC
Jan 19, 2004
  • Jan 19, 2004
I've read the reason that you are not supposed to jack your car up on the differential is because of some type of alignment issue. The differential has some type of alignment that may be messed up if you jack your car up on it. I'll try to find out where I read that.
G
GinoGT
1,862
Jan 19, 2004
  • Jan 19, 2004
Yes, the by-the-book way says not to lift from the differential. But go tell that to all the enthusiasts and mechanics who have been doing that for decades. Don't worry, it's fine. I've done it many times that way.
99SilverGT
1,660
Jacksonville, FL
Jan 19, 2004
  • Jan 19, 2004
I jacked mine up from the heavy duty brace right in front of the diff. Is it the axle carrier? Don't know, but its bolted straight to a crossmember. Probably the safest place to do it IMO. Its very beefy... and rusty...
G
GinoGT
1,862
Jan 19, 2004
  • Jan 19, 2004
You mean the 8 pound vibration dampening weight? The one that's held on by like 2 bolts and some rubber isolators?
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Jan 19, 2004
  • Jan 19, 2004
hope this helps
Jack point
Someone once told me that there is another jack point front of pumpkin somewhere
D
DerekStangGT
Feb 18, 2003
1,068
Jan 19, 2004
#10
  • Jan 19, 2004
  • #10
ok, ok, dang dude, calm down. you dont have to be so snippy. i get enough of that w/ my mom and sister
thanks for the diagram mity2. that's what i was lookin for.
VOORHEES
Stangnet's "35th Limited Edition" VIN Guy
3,046
36
119
LaGrange, GA
Jan 19, 2004
#11
  • Jan 19, 2004
  • #11
I also jack mine up at the differential. I use a folded towel between the two points to keep from having full metal on metal contac.
-Jason
mysticsvt496
260
maine
Jan 19, 2004
#12
  • Jan 19, 2004
  • #12
how come nobody has mentioned the framerails???????
GTMomma02
350
moving to CA...
Jan 19, 2004
#13
  • Jan 19, 2004
  • #13
Is this the same thing that looks like a dogbone? I used that instead of my differential before. I've also heard that people remove it for weight reduction. If I'm thinking of the same thing.
G
GinoGT
1,862
Jan 19, 2004
#14
  • Jan 19, 2004
  • #14
If what he's talking about is the dogbone, that is a big no-no to lift a car from that.
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
D
Drivetrain Where to place jackstands when servicing rear diff
  • dqureshi06
  • Oct 16, 2025
Fox 5.0 Mustang Tech Nov 2, 2025
limp
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
