  • SN95 4.6L Mustang Tech
Rear seal problem
  • Thread starter Thread starter N8Dogg98
  • Start date Start date Nov 5, 2007
N8Dogg98
3,872
238
184
MN
Nov 5, 2007
  • Nov 5, 2007
My rear diff is leaking from the front where the driveshaft goes in. There is diff fluid sprayed on the mufflers and the body above the diff. I have had the rear seal replaced at least twice in two years. Is there something that could be causing the rear seal to fail? Perhaps a problem with the yoke, pinion angle, or the actual housing itself? Any help would be appreciated...
lvmustanggt
721
Las Vegas
Nov 5, 2007
  • Nov 5, 2007
I just got mine done week ago along with my clutch.
N8Dogg98
3,872
238
184
MN
Nov 5, 2007
  • Nov 5, 2007
anyone?
yomadmike
55
Birmingham
Nov 5, 2007
  • Nov 5, 2007
sounds liek something might be misaligned, bent or out of balance. I'd start with the driveshaft.
blackfang
1,290
Richmond, Va
Nov 5, 2007
  • Nov 5, 2007
Not likely. All seals will eventually fail, this is no different. Just replace the seal and clean the area.
smokin91'
204
  • Nov 6, 2007
I just had mine replaced in my 02' at 57,000. Thankfully under warranty, I knew that ESP till 100,000k would come in handy.
blackfang
1,290
Richmond, Va
Nov 6, 2007
  • Nov 6, 2007
Already done mine in 2002 and have to do it again.
N8Dogg98
3,872
238
184
MN
Nov 6, 2007
  • Nov 6, 2007
This problem resulted in me having to rebuild the rear end about a year ago. Is it reasonable that the seal would fail again that quickly? How difficult is it to change the rear seal? Does the fluid need to be changed as well? If I use Mobil 1 75W 140 do I need the friction modifier? Thanks for the help.
blackfang
1,290
Richmond, Va
Nov 6, 2007
  • Nov 6, 2007
There is a good chance that it can fail again. Now how quickly, that depends on if the seal itself was bad or the install damaged it.
O
Progress Thread LTD-ing
  • OX1
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2026
OX1
O
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
