rear seat delete
  • Thread starter Thread starter 88mustng
  • Start date Start date Dec 20, 2004
88mustng
76
NJ
Dec 20, 2004
  • Dec 20, 2004
does anyone have any pictures of a nice looking rear seat delete in a hatch?
i wanna do this because i never ever use the rear seat. i know that it wieghs almost nothing anyway but i like the look of it.
thanks
steve
Mavrick
2,264
Collingwood, ON
Dec 20, 2004
  • Dec 20, 2004
50resto sells a kit, looks very clean.
five_o_stang
92
Georgia
Dec 20, 2004
  • Dec 20, 2004
http://photos.yahoo.com/five_o_stang
ok..so there's an enormous box in the way...but if you look at the pics you can see how I formed fitted the delete... The area under the box is just flat.
all you need is a 4X4 sheet of plywood, nails, automotive carpet and I used some heavy duty wire to put through two drilled holes in the back of the delete and wrapped them under the two little bolts under the hatch carpet..anyway...you'll get the idea....really easy to make...don't go buying some aftermarket expensive piece
good luck
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Dec 20, 2004
  • Dec 20, 2004
Once you remove all the brackets and hardware, the weight is quite considerable. Remove all the sound deadening material and that is even more weight off the car. Don't have any pics of mine right now, looks like hell, becuase it was more recent than not.
88mustng
76
NJ
Dec 20, 2004
  • Dec 20, 2004
thank you
that helps so much actually
i didnt think i would be able to have it all level like that. i thought i would need to put a step in it just thinking about it. now i know that i defs wanna do it.
thanks again
BlackDrop50
217
Bay Area, CA
Dec 21, 2004
  • Dec 21, 2004
Yep the rear bench seat cushion is light but the rear seats are about 15-20lbs, plus the sound deadener at about 3-4 lbs
281pony
2,681
Oly, WA
Dec 21, 2004
  • Dec 21, 2004
the seatbelts are probably 5 pounds each also, then there is some brackets and bolts which are probably another 5 pounds.
i removed my seatbacks and the vinyl cover. i left just the base cushion and set my amps on each side and my 6x9's in the center. it looks better then the dropoff it had before with the base cushion gone.
ive been meaning to make it all level like the ones five-o-stang linked. do you guys just get all new hatch carpeting and cover it with one piece?
Fox Full set of seats in the back of a hatch
  • keel
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2026
keel
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
Fox Rear Seat Belts - 87-89 vs 90-93 length
  • dan50
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
Mustang5L5
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
4K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
