Rear suspension help
  • Thread starter Thread starter squidz
  • Start date Start date May 7, 2009
squidz
22
  • May 7, 2009
My car is finally done, now I have noticed that the passenger side rear sits a 1/4 inch higher than the driver side. How can I fix this. The springs were replaced with global west leafs and have been on the car for about a yr now. I'm planning on lowering with blocks. Should I machine down one of the blocks to compensate or is there another solution?
Thanks!
2+2GT
3,333
10
79
Southeastern Pennsylvania
May 7, 2009
  • May 7, 2009
The front suspension is much stronger than the rear. A weak coil, twisted sway bar, damaged end link, or other such front end problem is much more likely.
squidz
22
  • May 7, 2009
Sorry, I'm confused. I've checked the fronts and they are equal height. The fronts have new springs and sway bar as well. The passenger REAR is higher than the driver side. How can I correct this with the front?
2+2GT
3,333
10
79
May 7, 2009
  • May 7, 2009
Um, since the front of the car is connected to the rear, either the surface you checked it on is uneven, requiring you to move the car elsewhere, or the car is twisted and you need the services of a frame shop.
As to the front/rear springs, it is not uncommon for the front springs to be twice the strength of the rears, causing any problem with the front to show up in the rear as well.
G
Grabber70Mach
305
Indian Head, MD
May 7, 2009
  • May 7, 2009
When you installed the new rear springs did you tighten the spring bolts with weight on the car or with it suspended in the air? It should be tightened with the weight on the wheels.
2+2GT
3,333
10
79
May 7, 2009
  • May 7, 2009
Quite true! This is also true of the inner (bushing) end of the lower control arms in the front.
squidz
22
  • May 7, 2009
It was tightened while on the hoist. OK I'll try loosening and tightening it on the ground.
hipo_p51
199
  • May 7, 2009
my car was a little off, but leveled off. drive the car and see what happens. by the way, the body is straight
2+2GT
3,333
10
79
May 8, 2009
  • May 8, 2009
Must be the floor you used to measure, then. If the front end is level, the rear cannot be sagging on one side. I mean, the front end is welded to the back end, right?
latamud
791
Tampa, FL
May 8, 2009
#10
  • May 8, 2009
  • #10
An easier way of looking at this, say you have a 4 legged table, and one of the front legs is ever so slightly longer. The longer leg lifts higher and the opposite rear leg gets more weight transferred to it, but since its springy it sink. My body looks straight but it's level up front and the rear is off 1/4 side to side.
2+2GT
3,333
10
79
May 8, 2009
#11
  • May 8, 2009
  • #11
I would consider a twist of only 1/4" as within original factory specifications, and on a 45 year old car being only 1/4" off is pretty darn good. Don't worry about it.
hipo_p51
199
#12
  • May 8, 2009
  • #12
nope, checked it in different locations. my was about a 1/4 off as well. drove the car and it slowly improved. took time for everything to settle into place.
trust me, 20 years of mustang experience here. good luck.
2+2GT
3,333
10
79
May 8, 2009
#13
  • May 8, 2009
  • #13
I'll see your 20 and raise you 25. The Mustang I have now is my second (there were other later) which I purchased in 1973. Even before I could drive, my family had several, including a couple of K codes.
Sounds to me like your car is in pretty good shape. My current daily driver had about 3/8" twist from day one.
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
