Rear Tower brace?
  • Thread starter Thread starter 88Stangboy
  • Start date Start date Jan 3, 2006
88Stangboy
Banned
Dec 12, 2005
342
Greenville, SC
Jan 3, 2006
  • Jan 3, 2006
Anyone ever used a Rear strut tower brace? I was thinking of making my own
out of some steel i have laying around and i was wondering if anyone has any input on how much flex they take out of the chassis...is it even worth the effort if i have a 10 pnt. cage already?
jadedinpa
1,094
lancaster, pa
Jan 3, 2006
  • Jan 3, 2006
if you have a 10-point cage, don't bother.
88Stangboy
Banned
Dec 12, 2005
342
Greenville, SC
Jan 3, 2006
  • Jan 3, 2006
I was thinking that...i was just going to fabricate an 'X' type brace between the two towers in my trunk. But i probably wont bother now...anyone know about the solid engine mounts? Its a street driven car, about 3 times a week on average.
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Jan 3, 2006
  • Jan 3, 2006
well, would it help to put in a rear shock brace in a car that doesnt even have subframes like my own??
-adam
TrophyHead
1,195
11
49
PA
Jan 3, 2006
  • Jan 3, 2006
-adam
No.....there a waste of money. I forgot the reasoning.....something to do with not moving lateral?????
Subframe connectors are the ****nit though. Highly recommended. I'm sure you know that though.
TomCat
412
Utah
Jan 3, 2006
  • Jan 3, 2006
I have solids in mine... some people were saying that they'd stress the chassis over time if you do a lot of hard launches and stuff. Be warned though, they do increase the feelable vibrations... mine gets pretty shaky at times.
88Stangboy
Banned
Dec 12, 2005
342
Greenville, SC
Jan 3, 2006
  • Jan 3, 2006
My car shakes plenty anyhow, i was wondering because my engine mounts i have are pretty much shot and i was going to have to replace them and i was thinking of solids, eventually my car will be only a weekend car. So vibrations not really a concern...how bad though?
W
wazazzle
618
In the dumpster behind McDonalds. WA
Jan 3, 2006
  • Jan 3, 2006
Next time I do a rebuild, I'm going with solid motor and poly trans.
jadedinpa
1,094
lancaster, pa
Jan 4, 2006
  • Jan 4, 2006
solid motor mounts aren't bad at all. do it.
TrunkFunk
Banned
Dec 28, 2005
83
A1A - Beach Front Avenue ...
Jan 4, 2006
#10
  • Jan 4, 2006
  • #10
Every bit helps.
Subframes only tie the front frame to the rear. They tighten things up a bit, but they also leave plenty of lateral twist.
I had a set of subframes in a notch that actually made the rear seat framing squeek under accelerating load.
Ever seen a truck frame. They tie the rails together along the whole length of the frame. You don't see that kind of reinforcement in a fox stang ... not anywhere along the shotty (at best) split subframing.
_jb_
808
Michigan, Berrien County
Jan 4, 2006
#11
  • Jan 4, 2006
  • #11
I don't think it would hurt.
88Stangboy
Banned
Dec 12, 2005
342
Greenville, SC
Jan 5, 2006
#12
  • Jan 5, 2006
  • #12
well its going to weigh about 10 pnds if i make it out of 1 inch square tubing, so im wondering if its worth the weight addition. Remember i already have a 10 point roll cage in the car. So will it even matter if its in there or not?
5.0fox
410
buckley/enumclaw wa
Jan 5, 2006
#13
  • Jan 5, 2006
  • #13
dont waste the time and effort to build it. the rear towers arent as critical as the fronts.
Sicarius428
2,085
Jan 5, 2006
#14
  • Jan 5, 2006
  • #14
If you already have a cage, I doubt it will help very much.
Kevin
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Jan 5, 2006
#15
  • Jan 5, 2006
  • #15
The rear shocks have no involvement with rear end geometry at all. You can tie them into a 20 point roll cage and it won't really make a difference.
Instead of fabbing up a rear shock brace, you should invest that time into reinforcing the torque boxes.
TrunkFunk
Banned
Dec 28, 2005
83
Jan 5, 2006
#16
  • Jan 5, 2006
  • #16
The shock towers are just a point to tie the two sides of our unibody cars together at the rear.
The braces are not intended for shock travel distortion.
larrendeuce
649
Southern NJ
Jan 5, 2006
#17
  • Jan 5, 2006
  • #17
"One of the biggest problems facing the Mustang is the flexing of the rear shock towers. This effect becomes particularly acute when the car is equipped with a coil-over conversion kit. A simple section of tubing welding between the two towers can eliminate this problem. ....the brace can also be welded to the roll bar to provide additional rigidity." - Mustang Performance Handbook 2, William R. Mathis
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Jan 5, 2006
#18
  • Jan 5, 2006
  • #18
Well coil-overs are an entirely different animal. Now you are putting heavy loads on something that wasn't designed to take it. You SHOULD brace the rear shock towers with coil overs.
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
Frame rail strut tower repair
  • Creomod
  • Dec 5, 2024
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
Creomod
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
