Rear valance woes
  • Thread starter Thread starter robbz28
  • Start date Start date Sep 12, 2010
robbz28
775
Epps, LA
Sep 12, 2010
  • Sep 12, 2010
I know when it comes to body panels you can't beat OEM. Unfortunately my searching through the parts catalogs has yielded me no "ford tooling" or OEM 67 mustang GT rear valance, so I bought one of those 35 dollar aftermarkets and, well, I definately got what I paid for. All of the mounting tabs and holes lined up great, I was very pleased there, but when i got done I noticed that it was a good half an inch on each side too short. If something is too long, I can fix that, but too short?? Come on...Anyway, if any of you guys have a GT valance that you want to get rid of that fits, let me know, or if you know of any GOOD aftermarket valances, please point me in the right direction.
rusty428cj
943
267
104
Port Richey Fl
Sep 12, 2010
  • Sep 12, 2010
That is why it is welded on my 68 Coupe. We cut the ends off and added material than welded it on. Also if you look close there are no holes for the chrome around the taillights. The taillights mount from the inside with no trim.
robbz28
775
Epps, LA
Sep 13, 2010
  • Sep 13, 2010
Very slick, I also noticed that you had shaved the reverse lights. I am amateur body man at best, I can do anything really A professional can do, but i might have to do it more than once and take 2 weeks to work one dent out. I like the way you molded in the fender extensions too. I was thinking about using my original non-GT valance and just cutting my own exhaust cut-outs. I think I can modify that more easily than cutting and welding and adding to my other valance...
chris66dad
167
Benicia California
Sep 13, 2010
  • Sep 13, 2010
Had the same problem on my 66.
I had a 3/8 of gap on each side and just figured it was something I had to live with.
I feel sorry for someone who is replacing the rear quarters, light panel and valance all at the same time with these parts. Nothing would line up like you think it should.
rusty428cj
943
267
104
Port Richey Fl
Sep 13, 2010
  • Sep 13, 2010
It is a lot easier if you are making a restomod than you can weld everything together.
rusty428cj
943
267
104
Port Richey Fl
Sep 13, 2010
  • Sep 13, 2010
I forgot about the reverse lights
If you weld the valance on all you have to do is fill in the gap with a strip of metal than add bondo. It is a lot easier than trying to bolt it on and make the gaps right.
robbz28
775
Epps, LA
Sep 13, 2010
  • Sep 13, 2010
aint bondo just great.....in moderation
BuckeyeDemon
130
9
Cincinnati, OH
Sep 13, 2010
  • Sep 13, 2010
just add material to the ends, or maybe cut the end off, weld in a filler patch and dress it out.
spend a solid day on the panel, improve your bodywork skills, keep more money in your wallet and be done with it.
in the end you'll have something that probably fits better than what the factory did and you did it yourself.
this area wasn't the best from the factory anyways.
robbz28
775
Epps, LA
Sep 14, 2010
  • Sep 14, 2010
Adding material to the ends is PROBABLY what I will end up doing, but heres a thought, how about cutting it in half and adding material to the middle? That is only if i decide to NOT mold in the ends, just tighten up the gaps a bit.
I concur with the money saving, i have done everything mechanical to this car, and the floor pans, suspension, wiring, everything, i just really HATE body work, i bought all new metal from the doors forward, including doors, no rust to worry about or dents to beat out...
BuckeyeDemon
130
9
Cincinnati, OH
Sep 14, 2010
#10
  • Sep 14, 2010
  • #10
how does the valance contour match to the quarter? if it matches up nicely then maybe that's an option.
i would hate too see you add material near the middle too tighten the gaps only to be left with gaps that aren't consistent.
rusty428cj
943
267
104
Port Richey Fl
Sep 14, 2010
#11
  • Sep 14, 2010
  • #11
You will have a problem with bolting on your license plate.
robbz28
775
Epps, LA
Sep 15, 2010
#12
  • Sep 15, 2010
  • #12
Yeah, I thought about the license plate issue, but it won't be much material and the license plates are slotted. As far as my contours go, they look to be spot on, but after thinking about it last night, and looking at Rusty's pics, I have just about decided to just add to the ends and mold it in. Which brings me to my next thought, (not sure of the term) but basically taking the front bumper and cutting it and making it fit really snug up against the car, especially on the sides where it wraps around. I have seen it done a lot on like 67-68 camaros, looks really slick.
rusty428cj
943
267
104
Port Richey Fl
Sep 15, 2010
#13
  • Sep 15, 2010
  • #13
I did that to my rear fiberglass bumper. I'm not going to have a front bumper.
R
Red5oh
377
DFW, Texas
Sep 17, 2010
#14
  • Sep 17, 2010
  • #14
My first one was about 1.5 inches too long... then I got hit in the rear and the second was about 1/2 inch too short... I guess that is just bad, and you have to deal with it. The short is very easy to add metal on the ends with the welder, but the long one... you could see the cuts from the back. Mine is a restomod, so its not that big of a deal.
Good luck
M
For Sale 2012 Mustang GT front and rear lower valance. ($50 a set)
  • mgarcia7
  • Oct 4, 2025
  • S197 Mustangs For Sale (2005-14)
S197 Mustangs For Sale (2005-14) Oct 4, 2025
mgarcia7
M
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Yesterday at 7:51 AM
AlexM556
A
J
Rear alignment issues
  • Jayjay001
  • May 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
