Which ones?
The outer axle bearings and seals should be easy, remove the cover, drain the oil, remove the cross pin retaining bolt, pull the cross pin, push the axles in, remove the c-clips, remove the axles, then pull the seals, and then the outer bearings.
The pinion seal is a bit more involved, you have to remove the pinion nut, pull the yoke, change the seal and reinstall. However, you must retorque the pinion nut in small stages, to get the same preload. Best to get a book for that one.
The carrier and pinion bearings require removal of the carrier. That can also be done, but reassembly of the pinion, crush sleeve, yoke and nut takes some heavy torque, in small stages, to sneek up on the right value. You should have a detailed manual, or a friend with experience for this one.
