rebuild time
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
alright my motor has 191k on it. i bought a set of gaskets to rebuild the engine because i thought i had a head gasket leak. but anyways...what should i actually do when i finally get around to doing this. just everything up top...intake gaskets, head gaskets, and oil pan gaskets....or should i go for the gusto and replace everything. the car runs fine now...just dont really want to have my motor blow considering its my only form of transportation. any advice is appreciated
i would get it bored .30 over while you have it out if you want to rebuild it your gonna have to re-place more than the gasket's. but if you dont want to bore it just bu a re-build kit from summit. and put a nice size cam in it and be done also re-palce the valve seals on the heads and put in a new oil pump.
As stated above if you have the block out already...and you got some time...get the full rebuild kit from Summit, it sells for a bit over $400 and includes everthing you need..(gaskets, bearings, pistons, plugs, oil pump, etc.)
And yes go ahead and bore it to a 306 to get a fresh cylinder wall....
David
Yep if I remember correctly it is a bit over 400...if you have any Mustang magazines some of them have the part number in the ad for the rebuild kit and could help you find it a bit quicker...
Yeah that is my problem is finding a place around where I live that will rebuild it and that has a respectable name...
Good Luck with what you decide to do
David
