Regarding timing problems??
I have a few questions?
(1) Should a new rem. dist, be very hard to turn, to set the proper timing? Mine is almost not possible to move or turn.
(2) How do I know that my mechanic degreed my cam correctly? My car seams like it has a huge flat spot! It does not put correctly, feels as if the car is running at 8 degrees of timing, when it says with a timing light- that its at 14 or 15 degrees.
(3) Sometimes when I first get in the car, the car makes a popping noise from the intake, what is this? What causes this? This normally goes away, but it's almost as if the car is missing, or does not have enough timing? This only happens every once in a while when you first get the car running down the road.
Yes I use 93+ octanes, as well.
This is all on my 1993 Lx 5.0 Coupe.
Any help would be appreciated.
:bang: :bang: :bang: :bang: :bang: :bang:
Mods List
Here goes nothing
This is on a 93' LX 5.0 Coupe- 5 spd. Car, with a/c.
* Complete Holley System max Kit, with ported Holley heads. Luntai adjustable rockers.
* No computer tune or chip.
* Long tube Headers (Mack or BBK)
* Kirban Adjustable fuel pressure Reg. (Running like 42-44 lbs)
* AFM Power Pipe with 95 mm PAS Mass air. Calibrated to go with my 24 lb. injectors.
* New egr, new o2's, new dist, new tfi, new battery, new ac, new msd coil, new water pump, new ignition switch,
* Holley i think 75mm throttle body, and matching egr spacer.
* 255 in tank Holley fuel pump.
* RJM- 160 amp alt 3 g- with 2 gauge wiring. Also note I have made a 2 gauge ground for the motor.
* No cats/ no smog pump- I run the short belt.
* Dr. Gas X pipe - with out cats.
* Flow 3 chambers with stock tail pipes.
* Pro- 5.0 Shifter.
* McLeod clutch/ flywheel.
* Alum. Drive shaft.
* 3.73 rear end gears.
* 245/50/16 tires- stock wheels.
* Huge stereo.
* NX wet kit, 150 shot- but is not hooked up presently.
* Flex fan- but electric fan is on its way with a dc controller.
* Crossed drilled rotors.
* Sub frames, KYB shocks/struts- have billstein's to go on the rear, have not been installed yet. No springs yet, still searching for a good set.
* 3 core Be Cool radiator.
* Under drive pulleys.
Can’t think of anything else. If I have forgot something please let me know.
BTW- I normally run my car ay 14 degrees timing. If the cam is degreed right?
:nice:
Just to be clear, Cam timing and ignition timing are not related like I'm thinking you think they might be. The cam timing relates to valve events with regard to the piston reaching TDC, and ignition timing is how far before TDC the spark is fired.
Here u go
I understand that, but the dist. sits way to far over to the left hand side if your looking down at it. I have had a few people ask if the cam was degreed correctly. I'm thinking either that or something else. I just ordered new Taylor plugs and a ford racing new -cap/rotor/and bowl so all of that will be new.
But why is it with the new dist. that it is almost impossible to turn it? None of this makes and sense to me.
Thanks again
Are the TFI wires stretched?
Is the hold down loose enough?
With the distributor being 'off to the side', that's remedied by restabbing it into a more central position (so the TFI is in the middle of its usable movement pathway).
Here you go.
:notnice: The dist didn't want to go in. Yes we greased it. Yes we checked the part numbers. But have no idea why it does not want to move.
And it does not want to come out at all, as of right now. But the car has a huge flat spot, where it does not seam to really pull at all. Thus I was thinking something is up with the timing.
And no the tfi is not stretched out. The car just feels like its running at like 8 degrees of timing, and not at 14 degrees when the timing light says its at 14.
Thanks
:notnice:
Fix your distributor problems first before doing anything else.
When the distributor is out of the engine, it should be easy to turn by hand and not make any scraping noises.
Putting the distributor back in is fairly simple. Pull #1 sparkplug, put your finger in the sparkplug hole, crank the engine until you feel compression. Then line up the TDC mark on the balancer with the pointer on the engine block.
The distributor starts out with the #1 plug wire lined up at about 12:00 with you facing it. Align the rotor to about 11:00, since it will turn clockwise as it slides into place.
Align the distributor rotor up with the #1 position marked on the cap, slide the distributor down into the block, (you may have to wiggle the rotor slightly to get the gear to engage) and then note where the rotor is pointing. If it still lines up with #1 position on the cap, install the clamp and bolt. If not, pull it out and turn 1 tooth forwards or backwards and try again. Put the #1 spark plug back in and tighten it down, put the clamp on the distributor, but don't tighten it too much, as you will have to move the distributor to set the timing. Note that if it doesn't align perfectly with #1 position, you can turn the distributor until it does. The only problem is that if you are too far one way or the other, you can't turn the distributor enough to get the 10-14 degree optimum timing range.
At this point hook up all the wires, get out the timing light and start the engine. Set the timing where your car runs best. Don't forget to disconnect the SPOUT jumper connector when you set the timing, and plug it back in when you finish.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
attachment.php
Backfiring out the intake is either a valve stuck open or a lean mixture or spark plug wire(s) connected to the wrong cylinder(s). Check compression on all cylinders and then look for vacuum hoses loose, cracked, or misconnected. Check the line for the vapor recirculation system – it is easy to knock loose and not see it when you connect the air pump plumbing. If the vacuum line for the EGR valve and the air pump are cross connected, some very strange things can happen. Check the mass air flow electrical connection and see that it is tight, the same goes for the fuel injection wiring harness connectors up on top of the manifold near the firewall.
Sticking valves: If a intake valve is bent, has a bad spring or is misadjusted, the engine will sometimes backfire through the intake. Use a vacuum gauge connected to any convenient spot on the intake manifold. Run the engine at 1000 RPM & look for 18-21 inches of vacuum with a steady needle. A problem intake valve will make the vacuum gauge needle sweep 5-10 inches.
Lean fuel mixture breaks out into several sub categories:
A.). Vacuum leaks
B.) Air entering the intake without passing through the MAF.
C.) Failure of the MAF, BAP/MAP (Baro or Manifold Air Pressure, same sensor, different name), ACT (air charge temp), or ECT (engine coolant temp). These should set a code in the computer.
D.) Leaking exhaust gases from EGR valve at WOT or EGR opening when it should not be open.
E.) Poor fuel delivery due to bad fuel pump, clogged filter or bad fuel pump wiring. Look for low pressure or fluctuating pressure. Standard injector pressure is 39 PSI at idle, with the vacuum line disconnected from the regulator and capped.
F.) Clogged fuel injectors.- see the cylinder balance test below
H.) Fuel injector wiring problems causing injector not to deliver rated flow.
I.) Computer problems: (computer problems are not common like sensor problems)
J.). ROM has bad data in fuel or timing table. This should also set a code in the computer.
K.) Failure of one or more of the computer's driver transistors for the fuel injectors. No code set on this one. Use a noid test light to test the injector wiring & injector drivers,
L.) MAF calibration off or mismatched to injectors.
M.) ACT or ECT bad. Sometimes the sensors will be off calibration, but not bad enough to set a code. If they falsely read too high a temp, the engine will back off fuel delivery.
Cylinder balance test:
Warm the car's engine up to normal operating temperature. Use a jumper wire or paper clip to put the computer into test mode. Start the engine and let it go through the normal diagnostic tests, then quickly press the throttle to the floor. The engine RPM should exceed 2500 RPM's for a brief second. The engine RPM's will increase to about 1450-1600 RPM and hold steady. The engine will shut off power to each injector, one at a time. When it has sequenced through all 8 injectors, it will flash 9 for everything OK, or the number of the failing cylinder such as 2 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures. Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
index.php
index.php
attachment.php
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
