  • 2005 - 2009 Specific Tech
reinstalling the drive shaft
  • Thread starter Thread starter corey796
  • Start date Start date Sep 17, 2008
C
corey796
85
  • Sep 17, 2008
i am finishing up putting 410 gears in my 06gt i cant see the mark i put on the pinion flange but the mark is on the drive shaft i cant line up the holes the way there were
im saving the drivesahft for last and will check back later thanks for any help
K
killrb
135
Stanwood, Washington
Sep 18, 2008
  • Sep 18, 2008
I've put the stock drive shaft in 3 different times and have had no issues. I have never checked or marked mounting holes. So in my experience, it doesn't matter. Just put the shaft back in and enjoy it.
One thing I did notice, however, was that it worked best to only put the two bolts that support the hinge of the shaft in finger tight. Then tighten the yokes on each end down all the way and come back to those two support bolts. It seemed like everything went together easier that way.
Brandon
C
corey796
85
  • Sep 18, 2008
thanks man
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
