OK, a lot of you know, i'm putting an 87 5.0 into an 84 Rx-7. i was about to use an 88 lincoln, but got enough advise, not to do it. i'm glad i didnt. but, i've pulled out the bulk of the motor, and wiring harness, and computer. i tired to label everything as i disconnected it. my first question is, what all componets do i need for the 5.0 to run. its going to be smog legal, so i got all the emission stuff, its just a couple vaccum hoses hanging out. there are twohoses going into the passenger side fender, from a plastic (the thing the hoses connect too) its right on the back side of the shocktower. #2 do i need those?
#3 do i need the wiring harness, that comes out of the driver side firewall?
#4 the vaaccum line coming off the brake booster, can i take that off, and connect it to the Rx-7's brake booster. it also has a tube coming off the same location.
Micheal Yount, i know you can help, because of your conversion. i'm getting rid of the mustang on saturday, so i need to make sure i got all the parts i need off of it.
~Steve
~Steve
