  • 1994 - 1995 Specific Tech
Removing headlights?
  • Thread starter Thread starter click
  • Start date Start date Sep 4, 2004
C
click
142
  • Sep 4, 2004
I feel really stupid lol cause i cant figure out how to remove the headlight on my 94 GT. I want to get them out so i can wet sand them. THX
donjohn
1,757
Irvine - Southern California
Sep 4, 2004
  • Sep 4, 2004
it's actually a pretty difficult task... i can't remember exacly how to do it but i think there are 2? bolts in the back with nuts that you need a needle nose or a reg. plyers to get off. You sqeeze the sides of it and the in theory should slide off (maybe a little prying with a screwdriver on em)
i think when i replaced mine i just broke the black nuts but new ones came in the set
C
click
142
  • Sep 4, 2004
Yep i see what you mean. I have no idea how to get the bottom one out so i just gave up. That has to be the stupidest idea for holding headlights in.
RIO5.0
6,892
N.H.
Sep 4, 2004
  • Sep 4, 2004
remove the plastic radiator cover..
remove the pony badge..(torx bit with the hole in it)
remove the hood latch assy bolts..2
remove the plugs/bolts from the corner lamps and remove em.
remove bolts behind the corner lamps (2) each side
remove 4 bolts in the center of the headlight housing...in front of the condenser..2 each side..
unscrew and remove the headlight bulbs....
yank the entire assy....thats how I did mine...its not really all that hard...the assy goes in and out real easy...
or just use masking tape to protect everything real good...then have at it...
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 4, 2004
  • Sep 4, 2004
If you want to wetsand the headlights, then just take some garbage bags and masking tape, and mask off the rest of the car. That will prevent any accidental scratches in the paint.
That is how I did mine, and it came out great. Except I used #0000 super fine steel wool and clear spraypaint.
Scott
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
Electrical Headlight Harness Route
  • dan50
  • May 3, 2026
Fox 5.0 Mustang Tech May 3, 2026
dan50
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
