removing the dogbone
  • Thread starter Thread starter projectfiveo
  • Start date Start date Aug 7, 2006
P
projectfiveo
347
Aug 7, 2006
  • Aug 7, 2006
hey ive heard about removing the dogbone to get rid of vibration...well im finally going to do it, but i need to know how hard it is to remove?? does anyone have any pics of the dogbone?? and also im going to remove the front sway bar, how hard is that?
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Aug 8, 2006
  • Aug 8, 2006
Removing the dog bone should not make less vibration. It is there to REDUCE vibration. It is located on the bottom of the pumpkin, under where the driveshaft connects.
The sway bar, you remove the end links, and the mounts to the frame rails and it slides right out.
HISSIN50
34
129
Aug 8, 2006
  • Aug 8, 2006
I gotta say I dont get that one either Nick. I'll say that with his 3.73's, the dogbone isnt probably doing a whole lot but it's weight over the rear end........
In any case, since I havent done it, I cant say how to do it. I know it's been covered in past threads if ya get real antsy to get it done.
Good luck.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Aug 9, 2006
  • Aug 9, 2006
Its only held on by 2 bolts, I took mine off to clean it up and paint it last year.
TheBocSez
652
Converse, TX
Aug 9, 2006
  • Aug 9, 2006
Took mine off, no issues at all. Just remove the 2 bolts holding it on, then reattach the upper bracket that holds your bump stop with 2 shorter bolts. Done.
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
