Replace fuel pump connector
craknjak
WI
Hello,
Where can I purchase a new plug that plugs into the fuel pump assembly? It is the red plug that has two wires on it (that supplies voltage to just the fuel pump). My current one melted and I need to replace it.
Thanks
I would try Ford if you
are desprate. A junk yard with a few
mustangs would be an easy
fix.
You should be able to get the entire
length from clip to clip for a
few bucks.
^ yep. is it a factory fuel pump? or an aftermarket? www.latemodelrestoration.com sells a fuel pump hook-up kit for walbro pumps that work with a few other "brands". i just bought it a week ago to put my 255lph pump in. it's 12.95 for the hook up kit. here's a link to it:
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=HDW-9350D 1&comp=LRS
and a link to just the wiring pigtail which is 7.95:
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=LRS-9350HDW 1&comp=LRS
*EDIT* i just realized you're talking about the red connector on the harness that plugs into the top of the fuel pump...dealership MIGHT have it, doubtful though. you're best and cheapest bet is to go to a salvage yard.
