Replace? Upgrade? To What?
DRKSD
Iowa
Hey all,
Prior to purchasing my 99 GT earlier this month I had my mechanic do a pre-purchase inspection and it showed a handful of things that weren't bad yet but should be addressed in the near future.
First off was the battery. No brainer as it was the original battery on a 50k mile car. Replaced.
Next, Front Struts, Rear Shocks, and Axle Dampers. Finally, Valve Cover Gaskets. The mechanic said the front struts, rear shocks and Axle Dampers were leaking and/or showing signs of wear consistent with an upcoming failure. But the Valve Cover Gaskets were merely wet upon inspection but showing no real signs of leakage at this time.
I fully intended to add some lowering springs to my suspension anyway, so a new set of aftermarket shocks and struts seems like a good fix for those two issues.
My question comes up with the Axle Dampers. Ashamed to say that until earlier this afternoon I didn't even have a clue what these things even were. So, do I just replace these with OEM parts, or is there a reasonable priced alternative in the upgrade market that I should be looking into instead?
Help me out here StangNet, I'm hoping this is a pretty easy test of the collective knowledge banks.
Axle dampers are actually referred to as quad shocks on Mustangs (no one really calls them axle dampers anymore). There are a number of better aftermarket versions that are very cheap. For example, AmericanMuscle.com sells both KYB and Bilstein quad shocks. The KYB's list for $35 each and the Bilsteins are $90 each. Both of these far exceed OEM quality.
http://www.americanmuscle.com/99-04-shock-strut.html
OR you could just remove them all-together. The quad shocks are not an essential part of the rear suspension and won't hurt the car by eliminating them. A few people have removed theirs :shrug:
I'm not trying to start a debate but, my mechanic refused to removed my quad shocks he stated that the rear-end of the car will move like as if it had rear-steer. I'm seeing quad shocks may not play that important of a role in "drag strips" but, going around a corning with an already shaky rear end is asking for trouble.
Do a search, there was like a big debate sometime ago, actually W.M. Burns had a really great explaination on why the quad shocks should stay and its role.
The sole purpose of quad shocks is to reduce axle "wind up" and wheel hop. I dont see how they really affect the dynamics of how the rear suspension performs (ie how the car handles):shrug:
Either way, the KYB and Bilstein parts are pretty cheap.
Reactions: trombonedemon
I'm not willing to find out though the side effects of not having quads shocks, your right about the KYBs, those would be the ones to go with; the Bilsteins, one would be paying for the name more the anything else.
Thanks for the tips, guys. I probably never would have found 'axle dampers' anywhere on the stang mod websites. Now that I know they're quad shocks I have a place to start!
I wouldn't touch the valve cover gaskets until they actaully start to leak (if they do).
What I would do is replace your PCV valve. Could be bad and causing extra crankcase pressure, thus deteriorating your seals a little prematurely.
