  • SN95 4.6L Mustang Tech
replacement battery
  • Thread starter Thread starter ADRENLN
  • Start date Start date Mar 28, 2006
ADRENLN
2,342
NJ
Mar 28, 2006
  • Mar 28, 2006
had to get the factory one replaced. go a motorcraft battery. thing is it is not the one from the factory it is remanufactured by motorcraft or somthing like that.
anyway while im walking with it i can hear the fluid inside sloshing around alot more then the factory battery. does this sound normal? it also dont have an eye, hope it is good.
tomustang
Psychotic Member
3,434
McLean Hospital
Mar 28, 2006
  • Mar 28, 2006
where did you get it from?
the more squoshing sould is normal, my wal-mart battery does the same
ADRENLN
2,342
NJ
Mar 28, 2006
  • Mar 28, 2006
my buddy workd for bmw, and he ordered it for me through a company they go through that remanufactures batteries. i went to pick it up, and they had motorcraft everything.
DropTopPony
Noob Slayer
2,570
south jersey
Mar 28, 2006
  • Mar 28, 2006
you should have bought an Optima yellow top since you don't drive the car all the time. It would be able to be recharged many times and in the fall when you park your car you just give it a good charge and put it away until spring...then it will still be almost 100% charged. Worth the money if you don't drive it everyday all year.
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Mar 28, 2006
  • Mar 28, 2006
I'm with Bob. Shoot for an Optima product. They seem to be nearly bulletproof batteries.
ADRENLN
2,342
NJ
Mar 28, 2006
  • Mar 28, 2006
well i will look into the optima later on. i already got the mororcraft one though. the original was fine to sit for a week or so with no problems starting, i figure this one will be the same.
it has been a pain trying to put my battery tray back in though. i think i might be missine some bolts or somthing. i was without it so long i forget. i just have the 2 bolts screwed into the inside fender and that is all that seems to hold it. i know there is another long screw that supposed to go in the bottom but there is nothing there to screw in to.
seems pretty stable though. i will hook up the battery tonight and see if the thing is any good. think i should trickle charge it first?
timeless2
Admin Dude
202
154
the Shadow Gallery
Mar 28, 2006
  • Mar 28, 2006
I bet you'll hear those same sounds when charging it, too.
ADRENLN
2,342
NJ
Mar 28, 2006
  • Mar 28, 2006
what sounds? are you saying not to charge it?
timeless2
Admin Dude
202
154
the Shadow Gallery
Mar 28, 2006
  • Mar 28, 2006
No, do what is needed--just saying you will notice minor gurgling noises when charging a wet cell battery.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 28, 2006
#10
  • Mar 28, 2006
  • #10
I just put in a new battery tray, it was only $14 at the ford parts counter and had hold down clip and bolt included.
DropTopPony
Noob Slayer
2,570
south jersey
Mar 28, 2006
#11
  • Mar 28, 2006
  • #11
ah the old days
ADRENLN
2,342
NJ
Mar 28, 2006
#12
  • Mar 28, 2006
  • #12
oh sorry., i thought you were saying i should not charge it as it would be bad or somthing. i wasnt sure what you meant. thanks for the heads up though.
yea i think that is what im missing a hold down clip or somthing. oh well it seems stable. i just have to see if i can close the hood. and i think i put that little sleeve on backward. i have to switch that and im good. i might be too lazy and just leave it though.
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
  • Gulftown980x
  • Jul 29, 2026
squeak93
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
