  • SN95 4.6L Mustang Tech
replacing battery
  • Thread starter Thread starter arrested@125
  • Start date Start date Dec 26, 2006
A
arrested@125
138
Columbus, Oh
Dec 26, 2006
  • Dec 26, 2006
Well its time to replace my battery. I usually have my mechanic do this kind of stuff, but I'd like to do this myself. Anybody have an estimate as to how long this takes or any pointers. Thanks.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Dec 26, 2006
  • Dec 26, 2006
ten minute tops, just disconnect the negative cable first then the positive these are either a 10mm or 8mm cant remember, then there is a hold down at the bottom of teh battery next to where the radiator hose passes through i dont remember the size on that then you reinstall everything in revere order + pos first then - neg.
Superhereaux
chicks make me feel inadequate
538
South Texas
Dec 26, 2006
  • Dec 26, 2006
just look at it, this it not rocket surgery we're talking here
it's three bolts and 2 you don't even remove all the way
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Dec 26, 2006
  • Dec 26, 2006
funny you mention that cause i know a guy thinks its complicated to change a battery
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Dec 26, 2006
  • Dec 26, 2006
on fords i use a 8mm socket, a 1/4 drive ratchet and about a 6" long extension. disconnect the negative and positive, then use the extension and take out the hold down. pick it up and reut in the new one and reverse removal.
Superhereaux
538
South Texas
Dec 27, 2006
  • Dec 27, 2006
Whoa now!
we're not all Mechanical Engineers in here my friend
can you explain it for us normal folk?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Dec 27, 2006
  • Dec 27, 2006
tools required, 8mm socket, about a 6" long 1/4 drive extension, and a 1/4" drive ratchet.
loosen the negative, then positive ends. then take out the bolt holding in the holddown on the bottom of the battery. pick up the old battery. then clean the tray a little. then drop the new one in and do the reverse of disassembly.
im a tech at Sears, so i can have this all done in about 3 minutes(timed myself on a mustang once. i mostly do suspension and brake work, but sometimes i get stuck doing batteries. most fords are super easy. what takes longer is if one of the cable ends is bad and i have to put in a new one, that takes like 5 mintues.
joshheat25
871
Delaware
Dec 27, 2006
  • Dec 27, 2006
I need to replace my battery as well! It takes 2 minutes!
san~man
O-G
A little grass shack on a big lava rock
Dec 27, 2006
  • Dec 27, 2006
Well, if you put in a battery that's larger than the oem one, say an Optima Yellow Top, you'll need to modify the plastic part that holds down the battery.
Just an FYI.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Dec 27, 2006
#10
  • Dec 27, 2006
  • #10
thats true about the diff than normal size. i was just referring to using the same group 59 that came as factory, might be a 58R not at work to check.
A
arrested@125
138
Columbus, Oh
Dec 27, 2006
#11
  • Dec 27, 2006
  • #11
Great. Thanks for the replies. LIke I said, I've never done this and just wanted to make sure there was nothing special that I had to do.
DTNODYA
831
#12
  • Dec 27, 2006
  • #12
This thread trips me out.
Only thing I'll throw in is .. be sure that after you loosen the terminals or the bolt for the "hold down" that you do not set the ratchet on the battery top. One time, for some stupid reason, I layed the rachet down and the extension hit both terminals on the battery ... some scary ****!
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Dec 27, 2006
#13
  • Dec 27, 2006
  • #13
Just an FYI.
Good call, I was also going to suggest an Optima battery swap.....although I'd consider the deep cycle Yellow top overkill. I'm sure the Red Top optima will be more than enough.
H
Electrical 2003 GT convertible battery drain
  • Huggybear56
  • May 31, 2026
SN95 4.6L Mustang Tech May 31, 2026
Bronco2fan
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
M
Fox Random spike voltage (Need help from scope users)
  • martroy
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
martroy
M
Hi. I'm new. 98 Cobra Bent Axle.
  • sbk93036
  • Mar 28, 2026
SN95 4.6L Mustang Tech Oct 5, 2026
Mustang5L5
