  • 1994 - 1995 Specific Tech
Replacing rear diff cover
  • Thread starter Thread starter Joe 5.0
  • Start date Start date Mar 9, 2006
Joe 5.0
1,184
Macomb, MI (metro detroit)
Mar 9, 2006
  • Mar 9, 2006
mines REALLLY leaking now so i need to address it. I bought the chrome cover off summit and it came with a set of bolts. I know it just bolts on, but can i drain the fluid first so it doesnt make a mess? How about torque specs and what kind of fluid to refill it with?
Also should i use the gasket it came with, or just use some RTV?
R.J.
813
Warwick, Rhode Island
Mar 9, 2006
  • Mar 9, 2006
The fluid will drain when you take the cover off. Do the bottom bolts first and work your way up, you can get it to drain with out making a mess. TQ on the cover bolts is good-and-tight. Just use RTV for the gasket. Go with Moble 1 or Royal purple Synth gear oil. There is a lot of brands out there but these two are highly reccomended by many. Also get a bottle of Ford Fricton Modifier for the clutch discs in the diff.
I would do a Moble 1 or Royal Purple tranni fluid swap while your under the car.
GRGT1994
1,034
  • Mar 9, 2006
That friction modifier is stinky stuff, so put a big oil drain pan underneath. Then remove all but the last few bolts, leaving just a few bolts in on the top - loosen those, but not all the way. Then use a pry bar to break the seal and dump the oil. This way the oil will dump down in a somewhat controlled manner. If you take off all the bolts and pop the cover in one motion, you will have a mess.
Use a long pry bar so your arm is not under the rear end, unless you want a shower (again - it's really stinky stuff).
Since you are replacing the cap, you could drill a hole in the bottom of the old one to drain. But that's really overkill. You should be able to drain as I described without much trouble. And you risk knicking the gears if you drill the cap while installed. This brings up another point, you might want to use a replacement cap with a drain plug (for future use).
If you are really concerned about making a mess, then spread out a layer of newspapers (5 sheets thick or so) underneath the entire back of the car and dump kitty litter over all of that to absobe any mess. Again, overkill - but it won't hurt to have the kitty litter on hand.
Wow, I just wrote way too much on a pretty insignificant issue.
J
joekd
51
  • Mar 9, 2006
When I installed my TA diff cover I used black RTV, no gasket
94-302-vert
1,947
NE CT
Mar 9, 2006
  • Mar 9, 2006
you gotta remove the swaybar too.. but that is easy... then follwo directions above. I usually use a couple cans of brake cleaner and some lint free rags to clean out any residual stuff... last time I used valvoline gear oil and it has the friction modifier in it already...
Stangfreak95
add a 4
3,571
In your sister. If none, your mom
Mar 9, 2006
  • Mar 9, 2006
Absolutely no need to remove the swaybar dude. I did this a few times and the swaybar wasnt a problem at all.
94-302-vert
1,947
NE CT
Mar 9, 2006
  • Mar 9, 2006
How did you get it out?
I changed the fluid on mine in the fall and I could not figure out a way to remove the cover entirely with the swaybar in place.
Stangfreak95
add a 4
3,571
Mar 9, 2006
  • Mar 9, 2006
I guess you just pull it towards you in an angle or so to pass that "bubble" on the cover. Really I cant see how you werent able to do it. I even changed carriers twice in my driveway on the pavement with the swaybar in place as well
J
joekd
51
  • Mar 9, 2006
yeah, both my OEM cover and the TA both fit fine with the swaybar in place
GRGT1994
1,034
#10
  • Mar 9, 2006
  • #10
I swapped my gears (pulled the carrier chunk) with the sway bar in place. Shouldn't be a problem with just the cover.
Joe 5.0
1,184
Mar 9, 2006
#11
  • Mar 9, 2006
  • #11
Thanks guys, heading to the store right now to get the fluid, andgonnatackle this today.
I'm justgetting whatever they have at autozone, because in the next couple months I'm getting a new diff anyways, so its pointless to spend extra for the fluid when its getting replaced anyways. I just dont have the money right now to replace the diff, but its getting nice so I am gonna wanna drive it.
9
95stangGT
513
Buffalo, NY
Mar 9, 2006
#12
  • Mar 9, 2006
  • #12
delete.
Joe 5.0
1,184
Mar 9, 2006
#13
  • Mar 9, 2006
  • #13
95stangGT said:
delete.
I did the change, and it went pretty easy. No broken bolts, but also I only had like a cup of fluid in the axle. Good thing I didnt drive on it much the past couple months.
Actually filling it was the biggest pita, since I didnt have any hosing to snake to the fill hole, so I had to just be swift and tip the bottle quickly.
Anyways, thanks for the help guys.
BTW do I HAVE to put in friction modifier? I used the Valvoline synthetic fluid. They didnt have any modifier at autozone, and the local ford dealer was closed.
95cobraguy
637
11
Concord, NC by way of LI, NY
Mar 9, 2006
#14
  • Mar 9, 2006
  • #14
when i put in my trick flow cover i used the supplied gasket. why would anybody want to deal with sloppy rtv when a nice gasket is supplied? oh, i dont have a drop of fluid leaking.
94-302-vert
1,947
NE CT
Mar 10, 2006
#15
  • Mar 10, 2006
  • #15
I also used the valvoline high performance fluid and it had the friction modifier in it. If the rear end is not jerky or banging you should be OK.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
O
Progress Thread LTD-ing
  • OX1
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2026
OX1
O
Rear quarter window regulator
  • BADAZZOMBIE08
  • Mar 29, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 29, 2026
BADAZZOMBIE08
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
