Restomod engine rebuild
  • Thread starter Thread starter jamison42166
  • Start date Start date Nov 2, 2006
J
jamison42166
112
  • Nov 2, 2006
I decided to add some more performance to my stock 64 1/2 coupes engine.
I have added Edelbrock RPM heads, intake, cam and carb. Also installed are new lifters pushrods and im also thinking about doing roller rockers down the road. I am ditching the generator for a 1 wire billet alternator and im waiting on a backordered March pulley system. I am also doing cool flex hoses upper and lower and adding the KRC power steer pump to comliment my TCP power rack.
here is a pic of the engine when i first got the coupe a year ago:
http://pg.photos.yahoo.com/ph/jamison42166/detail?.dir=9e20&.dnm=8f5are2.jpg&.src=ph
Here is a current pic of the engine out of the car:
http://pg.photos.yahoo.com/ph/jamison42166/detail?.dir=9e20&.dnm=795fre2.jpg&.src=ph
I cant wait to get a pic of it when its all done and be able to drive it.. of course snow will probably be flying when its all said and done.. my only concern is getting all this stuff done and not being able to break the engine in.
SoCalCruising
2,437
SoCal
Nov 2, 2006
  • Nov 2, 2006
Looks really nice. Is it 260 or 289, or something else now?
J
jamison42166
112
  • Nov 2, 2006
it still is a 289... edelbrock claims 384 Hp with the package im using but its on a 302.. i think ill be happy if i get 300 hp. one we got it stripped to a bare block whoever had the car origionally must have taken great care of it the block was meticulous. didnt have to do a damn thing to it other than paint it.
T
tylerrocks
514
Big Spring, TX
Nov 2, 2006
  • Nov 2, 2006
You should exceed that power goal at the rear wheels.
iskwezm
4,159
20
79
Rowland Heights,California
Nov 2, 2006
  • Nov 2, 2006
jamison42166 said:
it still is a 289... edelbrock claims 384 Hp with the package im using but its on a 302.. i think ill be happy if i get 300 hp. .
dont hope for too much out of that package. The heads cc's are a little big and drop compression. It works ok, but only as a new build with different pistons to keep compression at 9.5+:1.I had the RPM's and had them ported,changed the springs(stock ones were too weak) and used the RPM cam and a Vic jr with a 750.I had it dynoed before my current engine (had some ignition isuues) and it barely made about 240 at the wheels.I think running right it have made about 290-300.
J
jamison42166
112
  • Nov 2, 2006
STREET LEGAL PERFORMER WITH 1.90" INTAKE VALVES
Chamber Size Intake Port Size Valve Sizes (in/ex) Bare (single) Complete (single)
60cc 170cc 1.90"/1.60" #60319 #60329
allcarfan
The Answer Man
2,458
North Atlanta
Nov 3, 2006
  • Nov 3, 2006
240 at the wheels is probably a little on the low side. Id estimate around 250-260 with a good tune. Good luck, engine looks great.
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
C
Stock 1993 charging issue at idle
  • Charlie1
  • Sep 21, 2025
Fox 5.0 Mustang Tech Sep 24, 2025
Mustang5L5
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
