Retorque Heads
  • Thread starter Thread starter MustangPaul
  • Start date Start date Sep 29, 2004
MustangPaul
514
South East Louisiana
Sep 29, 2004
  • Sep 29, 2004
Quick question: When you replace the head gaskets, do you need to retorque the heads after a certain time/mileage? If so, what?
Thanks!
D
D.Hearne
11,730
south louisiana
Sep 29, 2004
  • Sep 29, 2004
No retorqing needed unless the mfg of the head gaskets recommends it. If you used Felpro's, then do not retorque them.
MustangPaul
514
Sep 29, 2004
  • Sep 29, 2004
D--As always, many thanks. Felpros are what I have.
--P
D
D.Hearne
11,730
south louisiana
Sep 29, 2004
  • Sep 29, 2004
No problemo..................
Max Power
1,774
St Paul
Sep 30, 2004
  • Sep 30, 2004
I went to retorque my aluminum heads with Fel-Pro head gaskets because the Edelbrock instructions said to do it.
They didn't need it, the torque hadn't budged,
Engine Retorque lower intake manifold bolts
  • 91GTstroked
  • Sep 8, 2025
Fox 5.0 Mustang Tech Sep 8, 2025
D
Negative Grounds for 2008 4.0L
  • deadbeat
  • May 13, 2026
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech May 13, 2026
deadbeat
D
Engine Felpro 9333 pt1 (with 8psi boost)
  • JD1964
  • Jan 14, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
Qtrhrse23
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Monday at 4:43 AM
manicmechanic007
