Reusing Centerforce PP while installing new disc - What prep needs to be done?
  • Thread starter Thread starter 5spd GT
  • Start date Start date Nov 25, 2005
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 25, 2005
  • Nov 25, 2005
Well I want to reuse my pressure plate with a new disc and resurfaced flywheel. What can I do to the pressure plate to make sure it doesn't slip and grabs like it is supposed to and effectively.
Just clean it off with emory cloth or what?
Some say you can get the pressure plate resurfaced. That just doesn't seem natural to me Some say scrub it with grit paper to rough the surface up...I don't like that idea...
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 26, 2005
  • Nov 26, 2005
bump
diablostang
425
Raleigh, NC
Nov 26, 2005
  • Nov 26, 2005
At least use some brake-cleaner on it.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Nov 26, 2005
  • Nov 26, 2005
If it has any glazing on it then definatly scuff that off. Any hotspots, might as well replace it. Resurfacing the PP, I guess it could be done with the right equipment. I would definatly scuff it some to get a new surface.
green
291
  • Nov 26, 2005
i did that a few years ago with mine. the pp dident look to bad so i just threw it back together. never sliped yet.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 27, 2005
  • Nov 27, 2005
When you say scuff it up...what do you suggest? I just feel a bit scared to scratch the pressure plate surface up with some grit when it came "stock" shiny and flat
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 27, 2005
  • Nov 27, 2005
bump
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 28, 2005
  • Nov 28, 2005
Any further help?
SQUEEZE&STROKE
SOUTHERN CA
Nov 28, 2005
  • Nov 28, 2005
Use some 1000 grit sandpaper (wet sand it using rubbing alcohal) to remove the hotspots...use a sanding block or similar tool to keef it nice and flat.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 28, 2005
#10
  • Nov 28, 2005
  • #10
You won't like the answer --- but I'd replace the pressure plate and the disc as a unit. I wouldn't take a chance with the old pressure plate.
I think a machine shop is gonna have a hard time doing anything with the plate disc unless you disassemble the pressure plate.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 28, 2005
#11
  • Nov 28, 2005
  • #11
So I can get that at wallieworld? So would that effect performance.
How does a hotspot (besides visually) hurt the grabbing ability of the pressure plate?
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 28, 2005
#12
  • Nov 28, 2005
  • #12
You might find the finer grits at WalMart - you may have to try Lowe's/Home Depot.
I believe I'd call Center Force's tech line and ask them about the surface prep requirements of the pres. plate face. Even with a sanding block, you won't be able to keep it flat/true -- except by dumb luck. And 1000-1200 grit is fine for polishing something -- but I'm guessing a polished pressure plate face isn't exactly what you're after for 'grab'. I'm sure there is a specific requirement for face finish and roughness -- akin to the machined surface they'll put on the pressure plate. But I'm pretty sure it's not the kind of micro-polished surface you're gonna get with 1000 grit paper or emery cloth.
Hot spots change the hardness of the local area that was affected. When the hardness is changed - the coefficient of friction is different. Different friction coefficients lead to grabbing -- and will also wear the clutch disc unevenly.
I think the worst case is that you end up having to go back in and replace the disc again, along with replacing the pressure plate anyway.
I believe this is an area where trying to save a few $ is gonna cost you more in the long run -- especially if it's been slipping due to being wet with oil.
SQUEEZE&STROKE
SOUTHERN CA
Nov 28, 2005
#13
  • Nov 28, 2005
  • #13
I only threw out the 1000grit as a suggestion to remove hot spots but when I did this...(By no means am I reccomending this!!!) I just hit it up with a die grinder and some smei fine sanding discs...has worked great for me...I hit up both the PP and the FW.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 29, 2005
#14
  • Nov 29, 2005
  • #14
I'm going to fire off an email to Centerforce and see what they say...I'll report back
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 29, 2005
#15
  • Nov 29, 2005
  • #15
I think that's a splendid idea!
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 29, 2005
#16
  • Nov 29, 2005
  • #16
Quote for quote from Brian at CF:
"I would recommend cleaning the pressure plate as good as possibly with some acetone to remove all the oil/grease. If you have excess to a sand/bead blaster I recommend to sand/bead blast the area that the disc rides on. Make sure you blow out all the sand as best as possible to ensure you will not have any operating difficulties.
Sincerely.
Brian Hankla
Tech Support
Centerforce Clutch"
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 29, 2005
#17
  • Nov 29, 2005
  • #17
....not at all what I expected....sandblasting is about as inexact as it comes for ending up with a flat/true surface. I'm not sure your tech there knows what he's talking about David. I believe I'd use 60 grit sandpaper on a block in a random pattern instead of blasting it --- but that's just me.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 30, 2005
#18
  • Nov 30, 2005
  • #18
I understand your thoughts (honestly)
The pressure plate is bolted (pressed) against the disc while the clutch is engaged...I'm sure the ridges from the beading overcome the "non-flat surface" that is possible. I don't think you would bead it long enough to make any imperfections in the flatness.
He has been very helpful and always quick to reply everytime I have asked him a question. Probably my 5 or 6th one to him alone...
It makes sense, I think, but I don't have access to one. I'm probably going to clean it off really really good and look for visual damage and go from there.
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
96-2001 Clutches, My Understanding Of Them
  • 1987stangman
  • May 26, 2014
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2014
COramprat
Drivetrain New Clutch Picks Up At Top Of Pedal Travel
  • o3504bbl
  • Aug 20, 2013
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 1, 2013
COramprat
Install '87-'95 Heads, Cam, Intake Install
  • 5spd GT
  • Sep 25, 2013
  • Resource Discussion Forum
12K
Resource Discussion Forum Sep 26, 2013
Gearbanger 101
You Get What You Pay For...When Will I Ever Learn???
  • flstang65
  • Dec 29, 2008
1996 - 2004 SN95 Mustang -General/Talk- Dec 30, 2008
flstang65
