  • SN95 4.6L Mustang Tech
rocker problem??
  • Thread starter Thread starter stang9gt
  • Start date Start date Aug 29, 2004
stang9gt
1,247
State College, Pa
Aug 29, 2004
  • Aug 29, 2004
Car was running bad so I pulled the valve covers off and one of my rockers was just sitting there on the bottom of the head??? They said I don't, but do I possibly need to shim my HP blower cams??? This is the second time this happened.....Should the rockers have a bit of play when they are on the base circle of the cam or should they always be tight???
F
fastback brian
540
So Cal , I.E.
Aug 30, 2004
  • Aug 30, 2004
they should have a preload on them at base circle. either the cams are ground to small or you could have a oiling or lifter problem, or possibly a sticking valve.
R
Rocketman
730
SoCal
Aug 30, 2004
  • Aug 30, 2004
From what I've read, you can pop a rocker off when you over rev. What is your rev. limiter set at. Might want to consider changing it.
stang9gt
1,247
State College, Pa
Aug 30, 2004
  • Aug 30, 2004
my rev. limit is at 6500....I didn't think that was a prob....I have some shims on the way for my lifters/lash adjusters...thought I would try those...
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
M
Pushrod length
  • mattcrp1
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 4, 2025
mattcrp1
M
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
  • Mindseye007
  • Aug 16, 2026
Mindseye007
