rod and piston question
  • Thread starter Thread starter curtisimo81
  • Start date Start date Feb 21, 2006
curtisimo81
33
pensacola,fl
Feb 21, 2006
  • Feb 21, 2006
Ok here it is i'm building a 347 stroker, does the connecting rod have to go into the piston a certain way, like does it matter which way you connect it to the wrist pin? all i see is the bearing retainers on one side of it so do they need to be on a certain side? any info will help...
dastang2
2,020
tx
Feb 21, 2006
  • Feb 21, 2006
yes it does matter but i can't explain the reason good enough, i am sure somebody will post that
vristang
4,933
101
124
Seattle
Feb 21, 2006
  • Feb 21, 2006
There should be a fillet on the big end of the rod that will run along the radius in the crank. The side that does not have the fillet will back up against the other rod.
Hope that made sense.
jason
curtisimo81
33
pensacola,fl
Feb 21, 2006
  • Feb 21, 2006
by the fillet are you talking about the two little marks on the rod?
dastang2
2,020
tx
Feb 21, 2006
  • Feb 21, 2006
he is talking about the beveled edges on the crank end of the rods. the flat edges butt up against the other flat surface on the rod. the beveled egde faces the counterweights of the crank. of course you know which way the pistons face right. the notch on the top will face the front of the engine.
curtisimo81
33
pensacola,fl
Feb 21, 2006
  • Feb 21, 2006
ok i got it, yeah i know about the pistons, just wasnt sure about the rods b/c i've had about three peep tell me it doesn't matter but i figured it did
retro50
191
Plymouth,MA
Feb 21, 2006
  • Feb 21, 2006
Pass side all the chamfers face forward towards the front of the engine. Drivers side all of the chamfers face the back of the engine. The pistons go in with the reliefs towards the lifter valley. Hope this helps.
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
G
4.6L rods and piston into a 5.4L
  • Green mustang
  • Jun 11, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 11, 2025
Green mustang
G
Engine Distributor Interchange List
  • Wayne Waldrep
  • Jun 21, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2026
dan50
