F fdc0844 New Member Mar 27, 2009 2 0 0 Mar 27, 2009 #1 Mar 27, 2009 #1 Has anyone replaced rod bearings while the motor was in the car. I have a faint knock that seems to be common in 4.6s my motor is 155k on it and runs very well. im going to pull the pan to inspect. has anyone caught a spun rod in time.
d98gt Founding Member Mar 14, 2002 4,505 59 204 SE Texas Mar 27, 2009 #2 Mar 27, 2009 #2 Even removing the oil pan is a PITA so honestly I think your best bet would be to take the engine out. Removing the engine isn't too difficult of a task (can be done in a driveway/garage) and you should replace all bearings once inside.
Skud Member Sep 10, 2003 493 0 17 Saskatchewan Mar 28, 2009 #3 Mar 28, 2009 #3 If you support the engine from above and drop the K member the pan is right there.. It would be pretty easy once you have the K member dropped.. Riley
