Roll cage question
  • Thread starter Thread starter fford
  • Start date Start date Jun 4, 2011
fford
1,020
Palmyra, PA
Jun 4, 2011
  • Jun 4, 2011
Hey guys,
I have an S&W 8point cage in the car and just got the 10 point conversion kit with a thru the dash front bars. I started to take the dash out and am seeing there is not a good strait thru shot in there. I have full HVAC controls in with a/c and was wondering if anyone has done this install before and what you had/have to trim to get it to fit?
This is the 92 hatch and the rest of the interior is out right now.
Thanks!
fford
1,020
Palmyra, PA
Jun 4, 2011
  • Jun 4, 2011
anyone?
9
90stang5speed
582
Columbus Ga
Jun 4, 2011
  • Jun 4, 2011
What I did with the front bars that go through the dash was to remove the dash speakers. On the drivers side I moved the fuse box over so the bar could fit. Also there where some kind of dash support bars on that side that I took out as well. Later I just got rid of the factory dash all together. I had already deleted the heat & AC before the cage so cant help ya there sorry.
fford
1,020
Palmyra, PA
Jun 5, 2011
  • Jun 5, 2011
Thanks, I was able to move the fuse box, I wasn't sure about that support thing, so I will pop that out. What I did with the blower box was to remove the front 1/2 that covers the blower cage, that gives me plenty of room for the bar, now I will just have to fab up a cover for that and all should drop right in. I am also going to have to use some flexible ducting for the vents.
Thanks again!
90 lx convert
Stanger
926
Falling Waters Wv.
Jun 5, 2011
  • Jun 5, 2011
fford, make sure to check access to your computer. When I did my dash bars thru the speakers they ended up blocking the computer. I used velcro to attach it to the heater box. Mike
fford
1,020
Palmyra, PA
Jun 5, 2011
  • Jun 5, 2011
90 lx convert,
good call. I will make sure to have access to that. On first look it seemed like it would be alright, but it might be tight.
Thanks
Progress Thread Roll cage and LS swap?????
  • 78mIIman
  • Dec 30, 2024
1974 - 1978 Mustang II Talk & Tech Mar 30, 2025
greenflash79
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
  • dan50
  • Jul 18, 2026
dan50
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
