roll pin size
  • Thread starter Thread starter 7tredmach
  • Start date Start date Mar 6, 2008
7tredmach
  • Mar 6, 2008
Anyone know the length, and diameter of the roll pin in the centerlink that alines the power steering control valve. Mine has sheered off, need to drill it out, and replace.
Thanks, Paul
yeloxr7
429
  • Mar 6, 2008
It cannot be drilled out. Just use the clamp to hold it in place. Mine broke off many years ago. I was not able to drill it out. Roll pins are made from pretty hard steel. My control valve has not moved with just the clamp (and threads in the valve/drag link).
7tredmach
  • Mar 7, 2008
ok, thanks for the info
Paul
stanger53
89
San Antonio, Texas
Mar 7, 2008
  • Mar 7, 2008
Roll Pin
Yes, the clamp will keep the control valve in place, but it is no problem to fix it right.
As stated before, the roll pin is very hard and cannot be easily drilled out. You can use a carbide end mill, but that is too much trouble.
Just use a 1/8" drill bit and drill a new hole 1/4" deep into the centerlink. Just keep it in line with the existing hole, and drill it inward on the centerlink a little ways. The centerlink is much easier to drill than the roll pin.
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
G
79 steering rack problems
  • garyrc
  • Mar 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
AeroCoupe
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
