roller rockers
  • Thread starter Thread starter monkeyman08880
  • Start date Start date Nov 27, 2004
M
monkeyman08880
54
  • Nov 27, 2004
Well id like to start off by saying that i am fairly new to engines, so i basically know just the basics (which i have learned from how stuff works.com and stangnet.com). My question is what is the difference between regular rocker arms and roller rockers? I understand that there is a difference is performance, and if i wanted to get roller rockers on my engine what would i have to do? Thanks.....
BC61
  • Nov 27, 2004
roller rockers use bearing at the pivot point and at the valve stem, regular rockers just slide metal to metal at the pivot and valve stem. thier purpose is to reduce friction. Installing them depends on the engine and type of rocker. It may be as easy as bolting them on or it may require drilling your head and putting in screw on rocker studds.
M
monkeyman08880
54
  • Nov 27, 2004
Well i have the edelbrock performer cam and heads.
M
monkeyman08880
54
  • Nov 27, 2004
And i forgot to add that it is a 1968 289 v8, with the stock rockers.
D
D.Hearne
11,730
south louisiana
Nov 28, 2004
  • Nov 28, 2004
The stock rockers don't actually slide across the valve stem tip. They roll also, the contact surface is slightly curved and so it does roll across the tip too.There are two types of roller rockers available, there's also a stock type with roller tips in addition to the full roller types. The full rollers give you the best bang for the buck, the biggest frictional loss is in the pivot.
CochinoFilipino
171
CA
Nov 28, 2004
  • Nov 28, 2004
I read an article in HotRod once. They added parts and dynoed the engine to seel how much each was worth. There was no change when they put on the Roller Rockers. Not to say that they are not better, but 'power' gains would be neglible.
thehueypilot
1,084
Medina,Tennessee
Nov 28, 2004
  • Nov 28, 2004
They basically reduce friction which lowers oil temp. and improves valve train geometry by reducing valve stem deflection against the valve guides which decreases guide wear. Less friction means more HP. But......if you install the wrong length push rods your guides will wear out in record time.
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
D
Early ford 302 heads
  • Dagasser
  • May 4, 2026
  • The Welcome Wagon
The Welcome Wagon May 4, 2026
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
