  • SN95 4.6L Mustang Tech
romeo or windsor?
  • Thread starter Thread starter sickazzstang
  • Start date Start date Oct 15, 2007
sickazzstang
55
  • Oct 15, 2007
Nick mckinney told me the answer but i forgot whats the difference betwwen the two? I know one has more crank bolts or head bolts then the other????
kylebgt
  • Oct 15, 2007
Other than a diff # of bolts here and there they are mechanically identical. One notable difference would be that the romeos have the updated aluminum x over intake manifold.
I BLAME TEH SOVIET CANUCKLAND FOR ALL THE FAULTY INTAKE MANIFOLDS!!!!!!!!!!!!!!
CobraRed_96_GT
1,421
UCSD/La Jolla
Oct 15, 2007
  • Oct 15, 2007
The 1996 thru 1998 Mustangs came with Romeo based engines. The 1999 thru 2000 Mustangs came with Windsor engines. Then just for fun, Ford went back to Romeo engines in the 2001 thru 2003 Mustangs. Romeo is 11 valve cover bolts and i believe windsor is 14
T
Trav4011
174
Oct 15, 2007
  • Oct 15, 2007
The windsor engines also have pistons with thicker top ring lands.. which makes them a little less prone to breakage under higher combustion pressures/temps.
A
avexhype
14
  • Oct 16, 2007
so is it ok to say....................................windsor FTW!!!! ?
RandyStinchcomb
1,159
Randallstown, Md
Oct 16, 2007
  • Oct 16, 2007
Windsor use a different jack screw then the Romeos, Windsors also have full floating pistons and pins, use the same con-rod as the Cobra, 8 bolt flywheel, different main bearings, 10mm hardware to hold the front cvr and assc on, double lipped frt crank seal, cams wth pressed on timing gears and prob somemore smaller items as well
joshjwc9
1,095
17
39
Palm Harbor, FL
Oct 16, 2007
  • Oct 16, 2007
Geez Randy, you probably typed that with your eyes closed.
And the Romeo's have the 6 bolt crank/flywheel?
RandyStinchcomb
1,159
Randallstown, Md
Oct 16, 2007
  • Oct 16, 2007
no-no, I was wide awake
yes & no, 2V Romeo's have 6 bolt crank/flywheel but the Aluminum DOHC's which are considered Romeo's have 8 bolt crank/flywheels
T
Trav4011
174
Oct 16, 2007
  • Oct 16, 2007
Just to clarify.. the windsor's 8 bolt crank isn't forged like the Cobra crank.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Oct 16, 2007
#10
  • Oct 16, 2007
  • #10
I'm not sure who fed you this info, but there's no truth to this what so ever.
No, I'm afraid not.
Here's a great guide that shows some of the differences between the Romeo and Windsor engines.....
http://www.babcox.com/editorial/ar/eb40228.htm
sickazzstang
55
#11
  • Oct 16, 2007
  • #11
Here is what I found.... http://findarticles.com/p/articles/mi_qa3828/is_199805/ai_n8791824 I wonder if one engine is stronger then another?
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
G
79 steering rack problems
  • garyrc
  • Mar 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
AeroCoupe
L
1996 harmonic balancer crank bolt. Help!
  • Lost in Palm Bay
  • Jul 21, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 24, 2026
Lost in Palm Bay
L
Am I crazy? Dad looking to buy 69 as daily
  • stonerCPA
  • Oct 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 18, 2026
nickyb
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
