Rough idle after heads/intake install
  • Thread starter Thread starter Soon2beBlown
  • Start date Start date Nov 18, 2004
Soon2beBlown
41
  • Nov 18, 2004
Well I just recently finished installing my twisted wedge heads and typhoon intake manifold. Theres no leaks, smoking, pinging or popping, just one amazingly rough idle. Not that the rpms are jumping, their holding dead even at 800 rpms but the whole car shakes while just idling. I'm only reading about 12lbs of vacuum at idle...shouldn't I be seeing about 20lbs? I've checked every vacuum source I could imagine...any suggestions on that? Also my roller rockers seem a little noisy, is this normal? Could the vacuum leaks be causing the rough idle? or maybe the big intake valves have something to do with it? The shaking actually lessens when I rev it up. Any feedback is greatly appreciated!
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Nov 18, 2004
  • Nov 18, 2004
vacuum leak= 12 lbs of vacuum /// no vacuum leak 16-18 lbs of vacuum .....
keep looking ...IMO
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Nov 18, 2004
  • Nov 18, 2004
Check to see how well the PCV grommet is fitting into the Typhoon intake, mine was very looks and was a vac leak. Also check to assure the "orange" ground is attached to the intake and not forgotten. For my PCV I pullled the grommet out and cleaned it, then with grommet in hand inserted the PCV valve and wraped the outer diameter of the grommet with electrical tape (5times) then shoved the grommet and pcv combinded into the hole....very snug, no more leak.
dastang2
2,020
tx
Nov 18, 2004
  • Nov 18, 2004
while running, get some starting fluid and spray over every gasket mating surface and vacuum hose, if it revs, there is a leak.are you positive, that you have the firing order on correctly also
Soon2beBlown
41
  • Nov 18, 2004
The pcv gromet is new so it shouldnt be leaking there. I'll try the starter fluid trick. I'm pretty positive I have the firing order correct, I never removed the wires from the dist. cap and marked the other ends to the correct cylinder. What about my roller rockers? is it normal that their kinda noisy?
dastang2
2,020
tx
Nov 18, 2004
  • Nov 18, 2004
roller rockers in general are noisy but probably when they are on top of aluminum heads, they make more noise
86T-Top
553
Dublin, PA
Nov 18, 2004
  • Nov 18, 2004
You got a vaccum leak there, unless you put a radical cam in but you didn't say anything about that. Check the seals between the intake and the heads with the starting fluid.
Mario
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
