  • SVT Tech Forum
RPM Drop!!
  • Thread starter Thread starter 01svtcobraxx5
  • Start date Start date Mar 20, 2011
01svtcobraxx5
  • Mar 20, 2011
Ok so i need some help. I own a 2001 Cobra with some upgrades. However about a couple months ago for some reason my Rpm will just drop all the way down to 0 and die. Just recently it started to get worse. Whenever i'm driving and I take it out of gear the RPM doesn't come down slow, and just falls all the way down until the engine dies on me, and it seems to wanna do it at the worst times like when im on the freeway or going down a hill. I think it might be my altenator but not sure. Appreciate any help thanks.
COBRA90GT
Mustang Master
Sep 22, 2001
6,654
HOCKEYTOWN ® , MI
Mar 25, 2011
  • Mar 25, 2011
Who told you the alternator was bad? Have you had the battery tested? How did that person come to that solution?
It sounds like a faulty IAC would be a more likely culprit or perhaps a vacuum leak(s), IMHO.
Also, what mods do you have ?
Performed any recent work under the hood, especially along the air intake tract (air filter, upper intake piping, etc)? Perhaps a recent mod or work under the hood has caused this drivability issue...
bditty50
170
Tampa, Florida
Jul 2, 2011
  • Jul 2, 2011
I bought my 01 cobra in Dec and had the same issues after doing my diablo predator tune to fix my gear change. So its when you come to a stop after the car is warm I'm sure it drops and you have to rev it or let it fall on its face. Well I was getting pissed with this and it made me not want to drive it. So long story short I replaced the IAC and it helped catch the drops alittle bit but, not fixed. So I updated the software on my predator and it is completely fixed. From what I've heard if you have a cold air intake the rush of air in the intake causes this and the IAC is stressed with the job of keeping idle. I also cleaned the Mass air sensor and that helped. So I would just recommend a tune and that should fix it.
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
L
A/C doesn't work after long drive
  • lking78
  • Jun 23, 2026
  • SVT Tech Forum
SVT Tech Forum Jun 30, 2026
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
  • SVT Tech Forum
