  • 1994 - 1995 Specific Tech
RPMs at idle?
  • Thread starter Thread starter 95strokerPSU
  • Start date Start date Nov 26, 2004
95strokerPSU
986
Sacramento from Philly
Nov 26, 2004
  • Nov 26, 2004
I've been trying to get my car to idle properly but haven't been successful. I know that if I hook up a voltmeter to the TPS that with the key on engine off it should be at about .95DC. I have to set mine to about 1.20DC to keep it from dying on me, and the RPMs are at about 1000-1100. I've tried adjusting the idle air screw and that hasn't helped. I have an A9L computer in the car so I have a barometric pressure sensor, but I've check that and it reads 160hz, which is fine. The fuel pressure is at about 43 and timing is set at 10*. Any ideas how I can get the car to idle at around 700 RPMs and have the TPS read .95 at idle?
HISSIN50
34
129
Nov 26, 2004
  • Nov 26, 2004
might want to cruise through this link and recheck it all. each page has info on a different aspect of getting the idle set.
http://www.muscularmustangs.com/iac.html
good luck.
mustang20010
60
  • Nov 27, 2004
First of all, when did your trouble begin? Did this happen all of a sudden? To set your idle, use this link http://www.stangtuning.com/showthread.php?t=1430 Besides following the instructions in that post, I think you could also benefit from some more timing. At least 14-16* I would think. I don't know the full details of your combo so it's hard to say on the fuel pressure, but 43 is the average setting, so it should be just fine. As far as trying to get your idle to 700rpm, that depends on your cam. I would think that (assuming all is well mechanically and you have no other existing problems) by following that link you should be able to get your idle very close to 700, but the rpm will vary based on the application. Obviously what works best for some isn't necessarily best for all.
Hope that helps.
willys1
1,004
New Jersey
Nov 27, 2004
  • Nov 27, 2004
Yeah,700 mite be too low,with a cam,you mite wanna bring it up a bit.
95strokerPSU
986
Nov 27, 2004
  • Nov 27, 2004
Turned out the seal between the upper and lower manifold wasn't tight. We blew smoke into a vacuum line and smoke poured out from there. Tighten it and I finally got to drive the car for the first time, runs great. As soon as I get all the small stuff finished I'll post pics of the finished product.
RIO5.0
6,892
N.H.
Nov 27, 2004
  • Nov 27, 2004
Cool...Dont you love a cheap fix.. Never heard of the smoke trick before...
mytight95
2,605
Dothan,Al
Nov 27, 2004
  • Nov 27, 2004
me neither that's kinda sweet........with what a smoke machine
jason
95strokerPSU
986
Nov 27, 2004
  • Nov 27, 2004
Yeah the guy I work on the car with has two in his shop. I think he uses them for emission/inspections. Definitely it's the easiest way to find a vac line leak. But I got to drive the car home and I'm really happy with how fast it is.
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
