I understand that the BBK throttle bodies have a idle air screw that you canroad rage said:When the car sits at idle (I warm it up) I can hear it in my house as it fluctuates. Also when I'm driving, I'll come to a stop and sometimes it will drop own to 500 rpm's and then go to around 700. Any ideas?![]()
idle air controllerDrK MrK iV said:I have the MAC 70mm TB too. It also does this. I'll check that screw on the top tomorrow as well. What does IAC stand for?
Replacing the IAC did NOT fix my idle drop problem. My IAC died and the new IAC still had the idle surge. I got an Accufab 75mm TB last month and adjusting the idle screw last week got rid of my idle drop (when coming to a stop). When I have the AC on it drops a little, but not as bad as before. With the AC off, it hasn't dropped since I adjusted the screwDrK MrK iV said:So do I adjust it or replace it or what? Im clueless with this.
