rtech pinion settingtool doesnt seem to work
rockyracoon
874
27
49
margate NJ
ratech pinion settingtool doesnt seem to work
I purchased the tool from ratech and if I follow the instructions it makes no sense,this is what they tell you to do
"With the tool being held by your left hand firmly against the top of the pinion head and the slotted end touching the face of the axle tube, insert the dial caliper with your right hand into the slot and position the depth rod so it touches the bottom of the carrier bearing journal. (fig. 6)
Take the measurement from the dial caliper and subtract it from the dimension printed on the tool. The answer is the current checking distance of the pinion gear. Add the appropriate amount of shims to arrive at the number marked on the end of the pinion gear by the manufacturer".
I get 0.510 from the dial caliper if I subtract that from the number printed on the tool (3.152) I get 2.642,the number on the pinion head is 2.550,how am I to add the appropriate shims to arrive at that number that is scribed on the pinion,when it is a lower number than the checking distance?
0.510 meaurment from dial caliper
3.152 number printed on tool
2.550 number on pinion
I dont get it.
I spoke to tech support over at ratech and the problem Im having is most likely in regards to a little plastic insert that is in the center of the tool which is supposed to go into the hole on the pinion head, however in my case that little nib wouldnt fit in the hole in the pinion thus not letting the tool sit flush on the pinion head and that changed the geometry in terms of the dial calipers results.They told me that is why they make that little nib out of plastic so it can be filed if necessary.Hopefully this will allow me to accurately achieve the correct pinion shim.
