  • SN95 4.6L Mustang Tech
run with Nitrous?
  • Thread starter Thread starter Mr GT 02
  • Start date Start date Dec 2, 2004
Mr GT 02
548
Peabody, MA
Dec 2, 2004
  • Dec 2, 2004
Yea so ..I never knew how to run with Nitrous. At WHAT point do u push the Nitro button??? can u spray as soon as your accelarating in 2nd????
billyfe390
573
  • Dec 2, 2004
Install a wide open throttle switch so when your foots to the floor its activated and install a window switch so you only spray between 3k and 6k.
I use this window switch.
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=208090&prmenbr=361
Get sticky tires and spray the bitch out of the hole.
02mingreyGT
280
Portales, NM
Dec 2, 2004
  • Dec 2, 2004
never spray below 3000 rpms ever, it could cause fuel puddling in the intake and your hood would look like a pyramid
BVille99GT
283
Brownsville TX.
Dec 3, 2004
  • Dec 3, 2004
With my NX set up I was using a Hurst shifter with a 12v button used to spray at will, but with my new set up (Noszle) it has a harness with WOT switch and RPM window switch. I always spray as soon as I see 2nd on the track, but will try out spraying out of the hole.
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Dec 3, 2004
  • Dec 3, 2004
A Nitrous Express 100 shot would be nice!When useing nitrous you make
it as safe as it's going to be.The thing about NX is that they rate there
shots at the wheels.The NOSzle set up is nice because it is direct port
and better for your plastic IP intake less chance of kaboom!If you know
how to use the wide open throttle switch and window switch correctly
then there will be no fuel puddling with the NX kit! Good Luck
lopey4.6
20+ Year Stangneter
Jan 4, 2004
309
Westlake,OH
Dec 3, 2004
  • Dec 3, 2004
This is true with a wet kit. A dry kit you can spray at 2600. If you have stock gearing you can spray in 1st gear if you have sticky tires. I run a NOS dry kit for 99+ cars. It's about as fail safe as you can get.
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
W
2008 wild stallion gt/cs. Rated over 600 HP with Nitrous. First Mustang ive owned. Fun car.
  • wild stallion
  • Aug 28, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 28, 2025
wild stallion
W
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
W
Tuner info.
  • wild stallion
  • Aug 28, 2025
2005 - 2014 S-197 Mustang -General/Talk- Aug 28, 2025
