running dual pipes???
  • Thread starter Thread starter curtisimo81
  • Start date Start date Jun 25, 2005
curtisimo81
33
pensacola,fl
Jun 25, 2005
  • Jun 25, 2005
i just converted a 4 cyl to a 302, i got a doubble hump crossmember, but i was told i'm gonna have to re run my fuel lines.. why? and if i do could i run rubber lines or should i run metal?
blkstangman88
646
  • Jun 25, 2005
on a 302 theres matal lines from the tank...(almost)...to the bottom on the engine, then theres a hard plastic line, then metal again to the injectors, when i pulled my engine out i cut the plastic line and just reunstalled 2 new fuel injector lines that were 12in long each......id say as long as the entire line isnt going to be rubber go ahead.
Vipersix
434
Clarksville, TN
Jun 25, 2005
  • Jun 25, 2005
The only thing you'll have to be concerned with is the fuel line diameter. Obviously the 302 drinks more go-juice than a 4 banger so it needs a larger tube to quench its thirst. Stock 302 lines are 5/16" OD that are good for about 150 lph. If you have a tube that is too small there is a pressure drop in the line when sudden demands are made for fuel which causes a momentary lean condition or could even cause cavitation and cause your motor to die. You may not need new lines... you just have to consider how much hp you plan on running and decide if your lines will be sufficient. The material of the line is inconsequential.
Fuel Volume (lph) = HP X bsfc X .6094 X 1.3
R
ratrapp2
121
  • Jun 25, 2005
i just bought a used set of fuel lines and replaced mine.the previous owner had took rubber hose and used about 6ft. off it by wrapping it around the rack.i tried to buy new lines but ford has discontinued them.
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
M
Hey all
  • Mikalikey
  • Aug 20, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 20, 2026
Mikalikey
M
9
1994 Mustang GT 5.0 L Convertible
  • 94ns95
  • Jun 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 19, 2026
94ns95
9
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
