Running hot!
  • Thread starter Thread starter 1994superstang
  • Start date Start date Jul 13, 2010
1994superstang
  • Jul 13, 2010
I have a 94 supercharged cobra that runs hot about 210-220 degrees. Has anyone had this problem and if so any luck with a larger or dual fan?
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Jul 13, 2010
  • Jul 13, 2010
Does the engine ever run cool? Our engines would overheat without the fan on surface streets. When you hit about 40mph or faster, the engine temperature should start going down. This of course will depend on how hot it is outside. Also know that the Cobra's computer will turn the fans on later than it will on the GT, so it will look like the car is running hot. In my experience, driving surface streets (and especially in traffic) the temp will rise up and the fans will turn on now & then to bring the temps down. The temp will never really drop past that point unless you jump on the freeway and drive for a while. This is actually normal.
Have you checked the Cobra's computer to see if it's really getting that hot? There are two temperature sensors on the engine; if one or both are bad, you could get a false reading. Do you have an engine code reader that can read PIDs (engine sensors)? This will tell you if the computer is getting the correct temperature reading. If it's not, the computer will keep trying to heat up the engine and raise engine temps pretty high.
ProKiller
3,064
15
78
PA
Jul 14, 2010
  • Jul 14, 2010
what do you have done already? 180 t-stat? water wetter? alum rad? manual fan switch? is everything functioning as it should?
Bosko5.0
1,067
longwood, FL
Jul 16, 2010
  • Jul 16, 2010
Thats almost normal running temp for a stock car 220 is when the fan goes to high speed.
91 LX 5.0 getting hot when a/c is running
  • 91lx14gt5.0s
  • Jun 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 4, 2026
manicmechanic007
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
84 turbo fan not working.
  • bdub_mkg
  • Jan 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 2, 2026
AeroCoupe
