Running issues
  • Thread starter Thread starter 1989DropTop
  • Start date Start date Oct 1, 2011
1989DropTop
269
18
29
Eatonville Washington
Oct 1, 2011
  • Oct 1, 2011
Well I got my vert of the garage for the first time in 3 months. I drove it down the street after warm up and found the car was missing. It would come alive if I put my foot into it. The car would shift in to overdrive and start running doggy as hell foot into it runs awsome. at idle has mild miss here and there but not too noticable. the most noticable is under load. I ran codes and get the basic crap for oxy sensors and idle high and out of range which is bs. The car is idling at 1000 rpm tops. The car is stock currently 5.0 automatic with 85,000 miles on it. New cap rotor plugs wires headers new oxy sensors, dumped codes and still get check engine light. Unplugged the light. so asking for some advice here on what the heck it could be. I am building a motor for it this winter but would like to take it out once and a while in the mean time. Brian
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Oct 1, 2011
  • Oct 1, 2011
1000 rpm is high. You should perform the idle reset procedure and bring it down to proper range.
O2 sensor codes are important, you'll want to address those.
If your check engine light is on, you have a major code stored. Did you run the codes with the engine running as well?
1989DropTop
269
18
29
Oct 1, 2011
  • Oct 1, 2011
Hey Mike Yes I ran with running and only code I get is rpm out of range running, not running I get o2 sensors but they are brand new 3 miles on them. I will look up the procedure for idle adjustment and reset dump the codes again. The engine light would go off and on as I drove the carat idle it was on at any type of rpm no engine light. Thanks for input. Brian
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Oct 1, 2011
  • Oct 1, 2011
Do you have the code numbers you got?
I have a few suggestions but need to know the specific o2 codes you got.
1989DropTop
269
18
29
Oct 1, 2011
  • Oct 1, 2011
12, 41, 91 are the only codes i am getting
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Oct 1, 2011
  • Oct 1, 2011
Those were the codes I was guessing you had.
So new o2s then? If so, usually double lean codes indicate an issue with something in the engine being out of tune. Could be a vacuum leak, dirty MAF sensor, egr valve stuck open, etc.
Is your smog system functional, do you have any smog codes?
Most of what I'm about to recommend is covered in this thread.
http://www.stangnet.com/mustang-forums/762521-code-41-91-a.html
1989DropTop
269
18
29
Oct 1, 2011
  • Oct 1, 2011
Thanks Mike I will read through it. I have all smog equipment and as far as I know all is fun****ional. Brian
1989DropTop
269
18
29
Oct 12, 2011
  • Oct 12, 2011
Hey Mike, I found nothing that would cause this after working on it for two weeks I found the bottom of the stock air box was not fastened properly letting air from the fan disrupt the air flow to the mas air flow sensor. Re sucured the air box and the thing runs like it should!!! Brian
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
J
Lack of power on acceleration
  • jameshernandez
  • Aug 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2026
jameshernandez
J
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
