My car is shaking badly, I replaced the balancer and I'm glad I did because the rubber was coming out of the stocker, however I still have the bad shaking.
I did a cylinder balance test, and #2 came up weak. I haven't had a chance to do much testing, but im confused. Sometimes the car runs perfect (like right after I changed the balencer.) I went home and went to drive to work and the damn shaking is back.
I unplugged #2 from the cap, and the car runs pretty much the same.
I guess I should try switching the wire, and then seeing if there is spark.
If I have spark, then its the injector? Can you buy just one injector? What else could it be? I also got the code that I'm running lean in the o2's.
