I do not how you did the smoke test. I figure you tried smoking through an manifold inlet or hose and watched for smoke out of the PCV valve socket.
I’ve never heard of this test, but here is a brainstorm. How about about doing a low pressure leak down test of the crank case? Do not go nuts and blow out the China rails seal or other gasket. But blocking off the PVC socket, and with a sealing oil cap, the crank case ought to hold 7 psi. If it is leaking, that should make a good hiss or breeze in the intake. If your valve covers or main seals are leaking, it might show that, too. But the hiss or breeze or holding pressure is what will be the tell.
with aftermarket cams until it’s tuned.
