Saggy Rear End
  • Thread starter Thread starter mustang11e
  • Start date Start date Sep 15, 2016
M
mustang11e
Active User
Sep 14, 2016
12
  • Sep 15, 2016
So I noticed the other day that the back end of my car was sitting lower than the front end. I talked to a friend and he said to get coil overs for the rear but I'm not sure if I wanna go that route. I was thinking of just getting lowering springs for all 4 corners. What would be the best route to go?
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Sep 16, 2016
  • Sep 16, 2016
what are you trying to accompish? You can just get a set of replacement shocks with new isolators if you want to get rid of the sag.
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Sep 16, 2016
  • Sep 16, 2016
The maximum motorsport or j&m adjustable control arms will kill 2 birds with one stone. Gives the ability to level out, amd gives a better performing control arm.
Joe
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Sep 16, 2016
  • Sep 16, 2016
Check to make sure one, or both of your rear springs isn't broken.
M
mustang11e
Active User
Sep 14, 2016
12
  • Sep 16, 2016
I was gonna go with replacement shocks but a guy who did some work on this said to get coil overs for it to level it back out and then I read else where to get lowering springs on all 4 corners.
Thanks for the reply
M
mustang11e
Active User
Sep 14, 2016
12
  • Sep 16, 2016
Will do thank you for the help
M
mustang11e
Active User
Sep 14, 2016
12
  • Sep 16, 2016
Joe
I will check into those, thank you for the help
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Sep 16, 2016
  • Sep 16, 2016
my bad,, I meant springs not shocks. IMO you do not want rear coilovers as they place all of the load for the springs on a small brakcet vs. on top of the control arm. I would check for sagging or broken springs and if you want to lower the car get a set of H&R or Steeda springs and Max Motorsports rear control arms.. you will need to replace all 4 springs and not just the rear. Might as well do the struts, shocks, sway bar and end links while you have it all apart. Expect to pay around $1000 when all is said and done for parts.
Mustang5L5
Mod Dude
Feb 18, 2001
43,349
18,085
224
Massachusetts
Sep 16, 2016
  • Sep 16, 2016
Sagging rear springs is common.
Sent from my big ass iPhone 6 using Tapatalk
Davedacarpainter
Nov 28, 2015
11,833
11,634
203
Discordia
Sep 17, 2016
#10
  • Sep 17, 2016
  • #10
Coilovers are nice, pricey, but nice. Go to Maximum Motorsports for their lower support bracket http://www.maximummotorsports.com/1979-04-Mustang-Lower-Shock-Mount-use-with-Coil-Over-kit-P610.aspx.
That'll take car of the flimsy OE ones.
I'm all about coilovers though, if you have the money.
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Rear quarter window regulator
  • BADAZZOMBIE08
  • Mar 29, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Mar 29, 2026
BADAZZOMBIE08
