Same Old Question!@! Idle Problem
  • Thread starter Thread starter PSloan
  • Start date Start date Jun 15, 2006
P
PSloan
  • Jun 15, 2006
I know you guys get tired of this question by I have tried every idea that I could find in the previous posts. I have and 89 LX but the motor and computer is out of a 91 GT (this car was factory a 4 cylinder car). The previous owner put the middle (I found that they had 3 cams on the web site and the model # was the middle one) trick flow cam and a GT-40 upper and lower intake on the car it is running the factory MAF and TB. The things that I have tried were flipping the IAC up side down, this made it idle way high so I tried to adjust the TPS to .98 volts once I did this it did not surge any more but the idle would stay at 1200 when it warmed up and would not fall (also would come down really slow between shifts)
So I went through the Surging Idle Check list and tried everything I could. The last thing I did was to flip the IAC back over and adjust the TPS to .90 now it will die when it is cold (in the morning if you don’t rev it till it has some temp it will die you cant just start it and let it warm up) and idle at 1000 when it is warm It also will die when you come to a stop sometimes not always it is almost like it can't catch its self. I would like to get it to idle below 900 rpms as to hear the cam and conserve some gas in traffic.
M
mkk50
109
29
39
Jun 15, 2006
  • Jun 15, 2006
i had a similar problem as to what your describing, and it turned out the previous owner had cleaned the throttle body, when it had that do not clean sticker, which cause the blade to stick slightly open. Try cleaning out the IAC real good, and check the tb to make sure it closes all the way, adjusting the stop screw if necessary
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
9
Electrical F150 ECU in a Foxbody? Idle surge help
  • 93royalblue
  • Sep 10, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
Mustang5L5
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
