Scratch your heads, is this possible?
  • Thread starter Thread starter natejones75
  • Start date Start date Jan 26, 2004
N
natejones75
58
Evansville, IN
Jan 26, 2004
  • Jan 26, 2004
I have a turbo unit from a 90's GT Probe, and my buddy has an identical set up that I could have. Here is my question?
1) Would it be possiblt to rig these up to run twin turbo on a small block
2) Could this be done wiht a carberated car or would it have to be EFI?
3) Besides the turbos themselves, what parts would be required to do this?
4) Is it possible? I want this to go in one of my 65 stangs (either carb or efi one)
I do not want to spend a lot of $$$, I have the donor cars, and I can fab things. Let me hear your feedback.
DarkBuddha
2,215
Seattle & Tampa
Jan 26, 2004
  • Jan 26, 2004
It can be done, it has been done, and it is being done by some folks on this board... You can do it with a carb or EFI, just depends on your preference. Plumbing and space will be the toughest parts to deal with as there just isn't a lot of room between the shocktowers and steering linkage to route stuff, so do lots of measuring.
As for what you need, check out http://www.toohighpsi.com, specifically http://www.toohighpsi.com/BudgetTT/BudgetTT.htm for a good overview of the kind of thing you're considering.
Sounds like a fun project... good luck.
taylor4g63
921
Asheboro, NC
Jan 26, 2004
  • Jan 26, 2004
also check out www.turbomustangs.com , lots of good info over there.
M
Mosse
229
Finland, Tampere
Jan 26, 2004
  • Jan 26, 2004
Just make sure Turbos are big enough, although smaller turbo gives better response, it may resist exhaust too much and melt your pistons... I´d try it. With 9,0:1 compression it´ll make serious hp even with 5 psi pressures.
M
Mosse
229
Finland, Tampere
Jan 28, 2004
  • Jan 28, 2004
Check this out... Looks good, doesn´t it...
http://www.fasttrackperformance.com/page5/chow movie files/christtgn.wmv
F
Fostang
1,400
Stockton, Ca
Jan 28, 2004
  • Jan 28, 2004
over a 1000 hp and slipping on the dyno thats awesome.
none67
352
  • Jan 28, 2004
wow. smoking on a dyno, you know you got power when..
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
J
Hello all, I have returned from a hiatus... Update and Questions
  • JackH
  • Aug 13, 2025
1974 - 1978 Mustang II Talk & Tech Aug 15, 2025
JackH
J
