screeching rear end
  • Thread starter Thread starter 95RoushV6
  • Start date Start date Apr 14, 2011
9
95RoushV6
  • Apr 14, 2011
I actually own a 95 3.8L Mustang, but I have a rear end from a '99 GT in it. For the last couple of months I would occasionally hear a screaching/grinding sound coming from my rear end while I'm accelerating or driving over dips in the road. I'm posting now because over the past week it has gotten really noticeable. Any ideas? I can't really discern whether it's my suspension or if it's coming from the differential.
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
Apr 14, 2011
  • Apr 14, 2011
Need to check brake pads and or get underneath the car to see if you can see rubbing spots, anything that was welded that has broken loose.
9
95RoushV6
  • Apr 14, 2011
well it happens when the rear end is under load, it wouldn't be low differential fluid or anything would it?
txredgt
1,343
33
69
Apr 14, 2011
  • Apr 14, 2011
Can you see any residue on the cover or have the gears been changed out recently? Why does it have a rear end out of a 99?
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
Apr 14, 2011
  • Apr 14, 2011
Look for some oil stains around the diff. cover and the back of the "pumpkin." If you have oil leaking from the driveshaft area, you need a diff. seal and the vent for the diff. housing might be clop, which would cause the seal to blow. Its very possible you too much play in where your pinion meets your gear, it could also be you need new U-joints.
Clunks are somewhat hard to find without regular maintenance for a vehicle by the original owner.
My lower control arms clunk sometimes (after market). My T45 transmission clunks. On take off, underload, the top of the diff. housing could be hitting the rubber stop (bad springs). Could also be upper control arms bushings, gone bad. Sounds are hard to diagnose over the internet.
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
