Are you sure the sct meters come with 6 pins? Again last I checked they didnt. Even if you do run a MAF that has a IAT sensor in the housing I would still run a external sensor in the discharge pype. With the IAT in the MAF in the intake (before the supercharger) your ecu is not seeing the real air temps and you will be more prone to detonation. So keep the maf connector and external IAT the way it is.
Even if the sct meter comes with a 6 pin you can still connect your current maf connector to it and it wont effect anything as long as you use a IAT sensor somewhere else, again preferably in the discharge pipe. Dont even think about splicing in a 6 pin connector.
I personally would rather run a larger MAF over a extender (like the mafia) there are different opinions on extenders out there and I just dont like the idea of them. Also you can find both the new ba 2600 and 3000 for about the same price. the 2600 is rated to 625hp witch is about what you wanted right?
If you are talking about buying a mafia and a ba 2400 I wouldnt. I doubt you would save any money over going with a ba 3000. Like I said though sct has a 2600 now that should do the job you need it to do without a problem. I know I will probably get flamed for this but rpmoutlet has them for $230 witch is $20 cheaper then I got my sniper bazooka 3000 for. If you order from them I recomend calling them and not ordering online. I have ordered from them 4 times and everytime I call and talk to someone and my order has never been screwed up.
